EMX Super 7 Weight
Old Nov 20, 2009 | 03:45 PM
The01Cav's Avatar
Default EMX Super 7 Weight
Does anyone have a rough idea of the weight of a EMX super 7? Just curious if they're a heavy wheel or not.
Old Nov 20, 2009 | 03:46 PM
thekevin's Avatar
i'd like to know too know that i have a set of them. i heard they're somewhat lightweight for 18s.
Old Nov 20, 2009 | 03:53 PM
The01Cav's Avatar
I am thinking about buying a set, just trying to decide what I want to do.
Old Nov 20, 2009 | 04:04 PM
speedy000's Avatar
22lbs a wheel.I have a set of rs1 emx's
Old Nov 20, 2009 | 04:54 PM
thekevin's Avatar
pretty good for stock 18s
Old Nov 20, 2009 | 04:57 PM
The01Cav's Avatar
Not too bad, sounds about the same as the stock 17's
Old Nov 20, 2009 | 10:34 PM
nodsetse's Avatar
Aren't the stock wheels 19 pounds? 3 more pounds per wheel, plus larger heavier tires, would be a fairly significant difference.
Old Nov 21, 2009 | 01:18 AM
thekevin's Avatar
the 17s are at least 24 lbs
Old Nov 21, 2009 | 04:06 AM
Yanki01's Avatar
Modified Magazine says both the stock and EMX rim are the same weight, doesnt say how much?
Old Nov 21, 2009 | 04:08 AM
DJ08tC's Avatar
The stock 17s are somewhere between 22-24 lbs, not sure of the exact some people say different but they are defiantly not below 20.
Old Nov 21, 2009 | 06:29 AM
speedy000's Avatar
I would think that having a bigger rim it would use a lower profile tire which would weight less than a normal profile tire....more rubber...
But I put my super7 rim on a bathroom scale it said 22...it could be wrong don't know how accurate it is.
But if they both weigh the same then I say the 17would be heavier with the bigger tires.
Old Nov 22, 2009 | 05:57 AM
YELOSUB's Avatar
Wagonistas
I have some 18" EMX Super 7's that I recently took off my xD and replaced them with Axis Decades that are just sitting in boxes in my garage...Tomorrow I will pull one out and weigh it for you and take a pic of it on the scale for proof...
The EMX Super 7's might be for sale soon without tires...Here's what they looked like on my xD:
Here's before I put them on:
Old Nov 22, 2009 | 09:31 PM
YELOSUB's Avatar
Wagonistas
As promised I just weighed them on my digital scale...I made sure to take off all the balancing weights prior to weighing it...My scale is pretty accurate...The Enkei Super 7's weigh in at 20.6 pounds...Not bad for an 18" rim...
Here is a pic:
Old Nov 22, 2009 | 09:54 PM
mindoculae's Avatar
thanks. good clean measurement. can you do the same with the stock rim ?
if you do a search for Scion Tc OEM rim, you will not find many sites that
provide the weight of the rim.
But one of the few that do states that a single OEM rim weighs 30 pounds.
Old Nov 22, 2009 | 09:57 PM
DJ08tC's Avatar
it is not 30 lbs, it is like 22, I have seen somebody on here that weighted it.
Old Nov 22, 2009 | 11:37 PM
YELOSUB's Avatar
Wagonistas
I would if I had a stock tC rim laying around But if I do recall, I remeber they were somewhere in the 22# range...
Old Nov 22, 2009 | 11:47 PM
YELOSUB's Avatar
Wagonistas
Here is an old thread I found while using the search feature: https://www.scionlife.com/forums/sho...ock+rim+weight
Old Nov 24, 2009 | 10:35 PM
The01Cav's Avatar
Yellowsub, PM sent.
Old Nov 30, 2009 | 03:02 PM
game-over's Avatar
and yello sun is dead nuts with the 18" (7's)
08_scion_tc weighed 20.6 also
Old Nov 30, 2009 | 03:21 PM
YELOSUB's Avatar
Wagonistas
Sweet that means my scale is accurate...Wait a minute, that sucks, my scale tells me i'm fat...
