transmission fluid and clutch recommendations
Old Dec 22, 2009 | 01:56 AM
badassco08's Avatar
Default transmission fluid and clutch recommendations
I heard that Royal Purple was great tranie fluid...Getting a new cluch installed and wanted some input...
I need some recomendations for a clutch kit. I looked on ebay and found these two that others have recommended on clubsciontc.com but what do you guys think of these two. The 2nd one is a TRD stage 1 for $139.00 from clutchmasters, The other is exedy $OEM clutch for 118.00
The shop said it would be approximately $1020.00 for a Luk OEM clutch kit and the flush of the tranie with the Royal purple tranie fluid...Seems a bit high since the Laybor is only $520.00 ?????
I dont really need anything to special. I drive 45 minutes on the highway with no traffic to work 6 days a week.
http://cgi.ebay.com/ebaymotors/EXEDY...Q5fAccessories
http://cgi.ebay.com/ebaymotors/04-07...Q5fAccessories
Old Dec 22, 2009 | 03:33 AM
Blue_TC_Man's Avatar
the exedy is nice, its OEM quality but grabs a bit harder, as for fluid redline MT-90 in my opinion
buy the clutch and fluid yourself, draining and refilling the tranny should be included in the shops install price. ask them what it will be if you bring in your own fluid and clutch. If you get the parts it shouldnt be more than 350-400
Old Dec 22, 2009 | 06:18 PM
skinnayyy's Avatar
Team Scionara
i've heard the royal purple trannie fluid is kinda bleh, nothing like the engine oil. MT-90 from redline is probably the most recommended on here though. If you are just using your car for a DD and not going to be adding a ton of horsepower i wouldn't really go with anything other than OEM clutch kit, but with the MT-90 alone you will notice a difference
Old Dec 22, 2009 | 06:44 PM
rosedaleny806's Avatar
redline is definatly NOT recommended, its ____ after 700-1000 miles it starts to jam up on u.
i went with eneos and its been a year and i have no complaints at all, one more flush and another eneos adding and the rest of that redline thats in there will be gone, and for a OEM style clutch id go with Exedy OE.
Old Dec 22, 2009 | 07:32 PM
thats not true, its been in mine and shifts golden after 10000 miles and ruf hard drag strip shifting.
If you use MTL in our cars it will lock up fast but mt-90 is great IMHO
Old Dec 22, 2009 | 07:36 PM
highvoltage1's Avatar
Eneos or Motul!
Old Dec 22, 2009 | 07:37 PM
my mt90 jammed, grinded and was just plain horrible in my tranny after only 700-900 miles. i got fed up and changed it out to eneos and havent had a problem since
Old Dec 22, 2009 | 08:40 PM
hmm I never had a problem out of mine neither has any of my buddies that use it
Old Dec 22, 2009 | 09:22 PM
skinnayyy's Avatar
Team Scionara
yeah i've heard nothing but good things about MT-90. i ran it on my stock clutch for a few thousand miles and it was great and now i'm on a clutch that will hold 400hp and it's still good.
Old Dec 22, 2009 | 11:20 PM
idk if it was a fluke. but on the "how to" thread on SL there's so many complaints about it after I complained. I have no clue.
I love my eneos though
Old Dec 23, 2009 | 04:15 AM
Hat_Trick_Hokie's Avatar
x2. I have been DD'ing and done one track weekend with the MT-90 and I haven't had any problems.
Good luck on the install.
Old Dec 23, 2009 | 05:01 AM
dodaddy's Avatar
I talked to one of the techs at toyota and they say they recommend 2.6 quarts of 75w90 tranny fluid. I am probably gonna run Royal Purple 75w90 personally.
Old Dec 23, 2009 | 05:08 AM
1989menace's Avatar
dont use RP Stephen, iv'e heard real bad reviews with there chemicals that make some bad affect on our trannys. mobil is real good. i would know! 2 tranny rebuilds already! and thanks for the clutch bro. ill shoot you a tex later
Old Dec 23, 2009 | 05:15 AM
dodaddy's Avatar
^^ ahh good to know, what weight of Mobil do you recommend?! And I'm definitely jealous you are gettin a twin disc, sooo baller!
Old Dec 23, 2009 | 01:39 PM
KCTTC's Avatar
I have 30,000 + miles of nothing but total abuse using Royal Purple 75w90. I'm going to be flushing it with some new Royal Purple over the holidays.
-Jeremy
Old Dec 23, 2009 | 03:39 PM
skinnayyy's Avatar
Team Scionara
still use 75w90. it's what the trans calls for.
Old Dec 29, 2009 | 05:01 AM
TJKASS's Avatar
RP is fairly good although theres still some question as to whether its chemical makeup is really safe for our transmissions synchros. Redline has always failed me in every toyota transaxle ive ever used it in (E153, E351, E350), personally the best ive found is what i have in there now. AMSOIL Manual Transmission & Transaxle Gear Lube 75W-90. Its GL4, and majorly synthetic. Never ground a gear since I put it in, and the difference between it and the Toyota fluid is night and day. Slightly higher price is worth it IMHO.
Old Dec 29, 2009 | 05:03 AM
TJKASS's Avatar
Just a note, we need the manual transaxle lube I specified in the post above, DO NOT get the synchromesh manual transmission fluid, they are worlds apart!
Old Jan 8, 2010 | 01:46 AM
SciMeiji's Avatar
Ive always been a royal purple guy and i especially love their motor oils but i will never use their 75w90 gear oil in my tranny ever again. My tranny used to be dead silent until i thought i was doing it a favor by replacing the factory fluid with the royal purp Synthetic gear oil. After a while my transmission started getting loud and whiney. Shifting became clunky and then one day over the summer it refused to let my shift into second gear with out hearing a blood currdling, god awful grinding noise everytime. Luckily toyota warrantied my tranny and i got a brand new one but i must tell u to stay away from royal purple synthetic max gear 75w90 gear oil. It will ____ in ur mouth.
Now im scared to ever switch my trans oil again. Might just stay with toyotas factory juice.
Old Jan 8, 2010 | 05:29 AM
KillaKeola's Avatar
What does toyota use? Eonos?
