TPMS system questions 2005 tC
Old Feb 7, 2010 | 01:13 AM
butter nuts's Avatar
Default TPMS system questions 2005 tC
My TPMS light is flashing along with a solid ABS light and the BRAKE light.
I think the tires are missing the pressure sensors inside, but I don't know the exact history of the car.
My question is; If the sensors are indeed missing, would this cause all 3 lights to come on?
And; Is there a reliable way to disable the TPMS system?
Old Feb 7, 2010 | 01:20 AM
DJ08tC's Avatar
05s dont have the sensors in the wheel so it is something else.
Old Feb 7, 2010 | 01:25 AM
Oh, strange. Thanks.
Any idea how the system operates? I had the lights scanned and 4 codes came back, one for each wheel it said something about a sensor but this was a long time ago and I forget.
Old Feb 7, 2010 | 01:31 AM
DJ08tC's Avatar
i believe 05-06s run off the abs system and measure wheel speed
Old Feb 7, 2010 | 01:47 AM
Do you know the method of resetting the system? I know there is a button but it does not do anything when I push it and I do not have the factory manuals.
Old Feb 7, 2010 | 03:17 AM
FreedomOne's Avatar
Hold the button down. Maybe disconnect the battery...
Old Feb 7, 2010 | 03:24 AM
Haha, really?
I found this on a Tacoma sight... to scan for ABS codes jump the #4 pin to the #13 pin on the OBD scanport, this will flash the codes. To reset, tap the brakes 8 times in 1/2 second intervals.. this will clear the stored codes. Any codes still left after clearing, look into repairs. I had one code left over, #32 front left speed sensor.
I pulled the wheel and the wiring was worn though... I'm assuming the moron previous owner and some retarded aftermarket wheels/suspension components. These aren't race cars. A little soldering and some 3-ply heat shrink and it's good to go.
FWIW I paid $4k for this pile of crap, put $200 in fixing the AC and a couple hours un-doing ricer mods now have it 100% problem free low mileage grocery getter.
Old Feb 7, 2010 | 03:26 AM
Steveo33186's Avatar
I have an 08 tc and you have to hold the butto down for 3 seconds (i think) untill the light starts to flash to reset it
Old Feb 7, 2010 | 03:43 AM
RoboCop's Avatar
After you turn the car on, hold the button in the glovebox down until the light turns off. That resets the light.
Old Feb 7, 2010 | 03:44 AM
SquallLHeart's Avatar
if you have an owner's manual.. the instructions would have told you to hold the reset button until the light flashes 3 times.
but yes.. your car does not use pressure sensors and goes off the ABS.
since the ABS sensors were messed up because of the worn and screwed up wires.. that's why both the ABS and the TPMS lights went on.
Old Feb 9, 2010 | 07:06 PM
JINeration's Avatar
lets just hope its not the abs sensors cause those cost and arm and a leg just for one
Old Feb 10, 2010 | 01:38 AM
Does anyone on here read before posting? Jesus.
Old Feb 13, 2010 | 10:23 AM
^^ yea.. i know.. some people are a little slow.. here.. i'll try again..
it's the abs sensors.. (or at least the wiring for them)
though i suppose he might argue well.. the sensors are technically okay.. blah blah blah..
Old Feb 13, 2010 | 02:58 PM
Originally Posted by butter nuts
Haha, really?
DERP
Old Feb 13, 2010 | 06:05 PM
DJ08tC's Avatar
you are a smart man calling a super mod retarded
Old Feb 13, 2010 | 10:54 PM
"Super mod" should know to read better than anyone...
Old Feb 13, 2010 | 11:13 PM
DJ08tC's Avatar
whatever dude you found your answer so you can leave. if you dont want people posting ask a mod to lock it.
Old Feb 14, 2010 | 02:29 AM
Kanchi's Avatar
Hopefully you will learn not to run your mouth from now on. This thread is done.
Old Feb 14, 2010 | 03:41 AM
this "super mod" quoted JINeration right before i posted.. because i was DIRECTING MY COMMENT to the SLOW PERSON in the first place.
i was agreeing with you. you said something about reading?
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
minter66
Dec 15, 2014 01:45 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
