xA Spring rates
Old Feb 14, 2005 | 09:28 PM
Ashe_WCM's Avatar
DeepSouth Scions
Default xA Spring rates
Looking around for some inexpensive springs I can use for AutoX untill I can afford the $1400 Coilovers I started checking the Different Brands Spring rates, I've emailed and/or called all of the Spring companys listed as having xA Springs in the SL part review area, Follows are the Claimed spring rates and drops for all of the companys that have responded.
Springs
Code:
                                          Spring Rate (lbs/in)                    Drop
                                          Front               Rear               Front     Rear
________________________________________________________
Stock                                 134                134               -0-        -0-
TRD                                   160                150             -1.0       -1.0
Tein
                      S-tech          145               179             -1.7        -1.7
                      H-tech          129               179             -1.1        -1.1
Megan Racing                    280               230             -1.85      -1.85
Tanabe
                     DF210           137               170             -2.0         -1.8
                     NF210           154               121             -1.3         -2.0
Eibach
             SPORTLINE      98-206*         57-229*      -2.0        -2.0
                     Pro-Kit     120-189*         69-211*      -1.5        -1.6
Goldline                              170               185              -2.0        -2.0
RS*R
            Downsprings          137               141              -2.0        -1.2
*Progressive springs
Coilovers
Code:
                # of Damper    Spring Rate (lbs/in)       Front Drop            Rear Drop
                Adjustments      Front         Rear           Max    Min             Max  Min
______________________________________________________________________
Tein
            SS    16                224          163             -2.4      -1.5           -2.5   -1.3
        Basic     0                 224          163             -2.4      -1.5           -2.5   -1.3
Tanabe
       S-OC                         275          165            -2.5       -0.25         -1.5   +0.25
    Type II                         275          165            -2.5       -0.25         -1.5   +0.25
JIC
    FLT-A2    15                275          165*          -2.5        -0.5           -2.5   -0.5
         SF-1      0                275          220*          -2.1        -0.5           -2.1   -0.5
*Progressive Springs
** Awaiting Further Info
I called H&R springs and was told "We dont keep that information available because most people just care about how much drop, and not every company measures spring rates the same". I'm not going to go into how springs are rated but I don't think this person has a clue.
If you have any requests just PM me or post here, and I will do all the research.
I'll update this post as more companys respond to my requests for information
***Added RS*R DownSprings***
***Added FLT-A2 Spring rates ***
***Added Coilover Listing 16Feb05***
***Added Goldline Springs 15Feb05***
***Edited math on Tanabe Springs***
***Added TRD Springs ***
Old Feb 14, 2005 | 10:01 PM
itzjere's Avatar
Great info! I just got H&R Race Springs... how do they measure spring rate anyways? Maybe I can do it and tell you so you can add to your chart.
Old Feb 14, 2005 | 11:59 PM
Ashe_WCM's Avatar
DeepSouth Scions
If its linear then you can either A> have someone do it. I know the Suspension place up the street from me did it for me (Where I got the Stock numbers from) check around where you live.
B> determine how many lbs it takes to compress one spring 1 inch. (amazingly simple isn't it?)
Old Feb 16, 2005 | 01:51 AM
Ashe_WCM's Avatar
DeepSouth Scions
Added Goldline Springs.
Old Feb 16, 2005 | 02:40 AM
LeeD's Avatar
Very nice list. Those Eibachs look awsome!!
Old Feb 16, 2005 | 03:03 AM
BeQuietAndDrive's Avatar
Ashe,
Do you have time to compile a list of coilover spring rates? I'm in the market for those, and it would be really helpful. Thanks.
Old Feb 16, 2005 | 09:10 PM
Ashe_WCM's Avatar
DeepSouth Scions
Added Coilovers
Old Feb 16, 2005 | 10:08 PM
mikochu's Avatar
sticky'd!
Old Feb 16, 2005 | 10:43 PM
Ashe_WCM's Avatar
DeepSouth Scions
Added FLT-A2 Info...
Also If anyone lives in the LA Area.. Ben Chen from JIC is looking for an xA to test fit an Exhaust, PM me for the info, First person wins
Old Feb 17, 2005 | 10:32 AM
Ashe_WCM's Avatar
DeepSouth Scions
Added RS*R Downsprings
Old Feb 18, 2005 | 12:53 AM
Does anyone know why the coilover spring rates have such dramatic differences between front and rear?
Old Feb 19, 2005 | 03:15 AM
Ashe_WCM's Avatar
DeepSouth Scions
I believe it is because of two things...
First most coilovers (if not all) are designed for autosports of some type.
JDM Sports companies have a tendency for a Front end Bias (Springs Higher in front than rear)
USDM Sports companies have a tendency for rear end bias.
All of the coilovers listed are from JDM companies..
For something that makes alot more sense check out...
http://honda-tech.com/zerothread?id=285747
Old Feb 24, 2005 | 01:43 AM
unlmtdndeavor's Avatar
Springs
Code:
Tein
Tanabe
Eibach
RS*R
Coilovers
Code:
Tein
Tanabe
JIC
wow...the megan springs have a higher spring rate then all of the coilovers??? and the rear is WAY higher...i wonder if thats a good or bad thing in this case?
Old Feb 24, 2005 | 03:12 PM
Ashe_WCM's Avatar
DeepSouth Scions
Springs can cause your car to act as if they are "Swaybars" i.e. the higher the spring rate the less lateral roll you notice on that end of the car... this will increase oversteer.
If thats good or bad is up to you..
Old Mar 5, 2005 | 05:46 PM
DTurnbull's Avatar
Just removed my Hotchkis springs the other day in favor of the Eibach Sportline. I have to say - I could not be happier! Without any settling, they are already a half inch lower than the Hotchkis, front & rear. And, coupled with the TRD shocks & struts, the ride is awesome and far, far, far superior to the Hotchkis springs! The springs are available at the TireRack though they did not have them listed on their website (they might now). If you're interested and don't see them, just give them a call.
David -
Old Mar 6, 2005 | 09:26 AM
JDM_Junkyard's Avatar
has anybody tried the HKS coilovers or the HKS springs yet?
Old Apr 11, 2005 | 11:14 PM
techick's Avatar
i ordered the megan springs... I don't know hwo they feel yet, haven't even recieved them yet... but they seem to be one of the best out there for the scions.. u know?
Old May 23, 2005 | 11:13 PM
mlimin's Avatar
Hi guys, I am a little bit confuse regarding spring rate for tanabe DF210.
I have just called tanabe in california, they told me the rear is progressive. so which one is the right info???
is H&R stiffer than eibach and tanabe df210?
Thanks
Masri
Old May 24, 2005 | 02:00 AM
Ashe_WCM's Avatar
DeepSouth Scions
Well the person I spoke to didn't mention the rear being Progressive, so I may have bad info from some fool. As for the H&R they wouldn't give me any info so I couldn't help you there....
Old May 27, 2005 | 09:05 AM
LeeD's Avatar
To give people a prespective on ride comfort vs suspension stiffness, let me tell a story,
About 2 weeks ago I went for a test drive on one of the new C6 corvettes. This peticular version that I drove had the higher performance suspension package. Z-something or other. Anyways, that thing road like a dream compared to my stock RS1.0. I could barely feel the highway reflector bumps that are on our California highways. Unlike on my xA RS1.0. Man, and what's funny is, a friend of mine that road in mine, but also road in a stock xB, said the xB was even STIFFER. Man, that's just wrong..
I told the guy I was most impressed with how soft the suspenion was for how well it held in the turns. He was suprised because he thought the suspension was kinda stiff, and he owns a C5 Z06. Ha..
Anyways,
point being, this is the perfect example of, going stiffer doesn't mean going faster.
