OFFSET issue with ROJa wheels .. lend me your ears
Old Feb 15, 2005 | 07:09 PM
Soon2BxB's Avatar
Default OFFSET issue with ROJa wheels .. lend me your ears
so i just got my wheels in the mail today
turns out they are a 17x7 with a 42 offset instead of the claimed 40 offset in the auction
i read through the fitment FAQ and didnt find my answer
am i going to run into any rubbing issues in the front/rear ..
and should i toss a spacer on the back to bring the wheel out a bit .. if so .. what spacer
thanx alot guys
Old Feb 15, 2005 | 08:05 PM
squirrel's Avatar
Hmm, front should be ok, rears may need a 3 mm spacer ring. Or, you can go w/ the 10mm One Ton Garage rear spacers and not have to worry about the spacer rings.
I have 17x7.5 w/ +42 offset up front and only rub on hard u-turns, and then its only on the inner plastic fender well, dropped at 2.5 inches and 2 degrees of camber.
In the rear, I have 3 degrees of camber.
Old Feb 15, 2005 | 08:59 PM
KevinxB's Avatar
I have 17x7 +40, no spacers, no rubbing. You should be ok.
Old Feb 15, 2005 | 09:02 PM
mikochu's Avatar
You should be a-okay. I would get rear hub spacers, though.
Old Feb 15, 2005 | 11:59 PM
Soon2BxB's Avatar
i plan to drop using goldlines .. so will the 42 offset wheels.. the 10mm hub spacers and the drop cause any problems together ?
will it give me the flush look in the back .. using all the numbers above?
thanx
Old Feb 16, 2005 | 03:13 AM
KevinxB's Avatar
Should be flush-esque with the spacers. I'm not sure how far you can go out without having to roll the fender lips, but I doubt +32 would give you any rubbing issues.
Old Feb 16, 2005 | 03:30 AM
xmetalx's Avatar
i just got some katana 18's and they rubbed, i had to slap on 1/8th inch spacers, kinda sucks, but no biggie. as long as the spacer size stays small you dont have to worry about them.
Old Feb 16, 2005 | 04:24 AM
Soon2BxB's Avatar
yeah im just going to pick up the shim spacers from one ton garage .... that should do the trick
install looks easy as well
Old Feb 16, 2005 | 04:34 AM
moonray's Avatar
You will be ok. 17x7.5 with that offset are close on the rear lower suspension, but with
the the seven '' wide wheels no problems. The hub spacers from 1tg will make it look better tho . I can't wait to do my mod's but I' m building a new house -- gotta save
Good sakes man - what are you going to do with that hair?
Rust never sleeps -- Neil Young
Sumolance
15
Jan 30, 2015 05:09 AM
gettoastedinthetoaster
Dec 29, 2014 11:39 PM
2010tc805
Scion tC 1G Wheel & Tire
Dec 12, 2014 06:47 PM
OOHC
9
Nov 18, 2003 03:41 PM
smilygo
Oct 1, 2003 07:03 AM
