camber correction kit?
Old Feb 17, 2005 | 04:57 AM
silver's Avatar
Default camber correction kit?
hello do you need the camber correction kit for the xb when running tanabe df210
or can you get the camber right with out it?
Old Feb 17, 2005 | 05:10 AM
hahajoey's Avatar
u can get the camber to a good setup without even a camber kit,...
im down about over 3" and i got it aligned with still less than 1.5 degrees in front.
Old Feb 17, 2005 | 05:26 AM
squarepants's Avatar
the front is no problem there is adjustment but the rear you will need to install shims if you want your wheels to look straight,mine is off as we speak just hope i'll get good tire wear without the shims..
Old Feb 17, 2005 | 10:39 AM
Ashe_WCM's Avatar
DeepSouth Scions
You shouldn't need to do anything in the rear to correct for camber, Camber shouldn't change with a Torsion bar suspension ( I may be wrong about this, but only because I never checked beacuse I never really doubted who I learned that from.)
Old Feb 17, 2005 | 04:47 PM
hahajoey's Avatar
i know that i had wheels on my car for a year, and i had even wear all the way around.. and i had it dropped over 3 inches.
all i did was get a alignment after i got my suspension dialed to where i wanted the ride height to be.
i didn't have uneven wear at all..
jcraff3
Feb 20, 2015 11:41 PM
TheTripleC
Jan 4, 2015 06:46 PM
kleecker
Jan 2, 2015 08:09 PM
Alvie
Dec 12, 2014 05:04 AM
Mr_Magu
Jan 17, 2004 05:21 AM
