quickshift install
Old Feb 17, 2005 | 08:14 PM
nhiiq's Avatar
Default quickshift install
Hello, i purchased a TRD quickshifter, and at first i attempted to install it myself. I got the center console off fine, then i ran into the problem of the wire harnesses along the passenger side of the shifter... i couldn't figure how to get them out, i pulled (but not too hard) then i tried to push from underneath and still not even a budge.
I then though of having toyota install it but they wanted to charge 2 hours worth of labor, $168!! -- no way.
so it's back to me installing again, the overall directions are easy to read, but a better description of how to remove the harnesses would be cool.
thanks, from a newb installer.
Old Feb 17, 2005 | 08:24 PM
VanillaRice's Avatar
I think I know what you are talking about. If I am understanding you correctly you need to use a razor blade to cut the green tape wrapped around the wires. Be careful not to cut any of the wires though! Then you can pull out the shifter housing and pop the tabs out from the underside and re-attach them to your new piece.
https://www.scionlife.com/forums/viewtopic.php?t=28859
Old Feb 18, 2005 | 01:46 AM
There's no need to cut anything
Just use a screwdriver underneath the plug and pop it out with a bit of leverage. Using your bare hands to pull it out is a bit difficult.
Old Feb 18, 2005 | 05:42 AM
nhiiq's Avatar
Thanks for the tips, it's just a little unnerving pulling apart some of this stuff.
Old Feb 18, 2005 | 07:42 AM
jspecbb's Avatar
i just recently did an install myself. luckily i didn't have to hard of time getting the clips off. how hard did you try pulling them off. mine's just popped right off. the harder part will taking off the shift cable clip from the whole unit. it says in the instructions to stick a screwdriver in the slot to "unlatch the claw" you have to twist the whole thing around just to get the screwdriver in. all in all, not too hard of an install. good luck and happy modding.
Old Feb 18, 2005 | 01:49 PM
You're right, there is not real need to cut the tape but you can do it that way. In my opinoin it made it go quicker. Just cut the tape, pop out the tabs and tape it back when you're done. Took about 10-12 minutes for the entire install.
SuBSiN
Mar 13, 2015 04:02 AM
randomsuper
Feb 27, 2015 01:29 AM
Frustratez
Feb 26, 2015 04:03 PM
ofgarcia
Dec 22, 2014 12:27 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
