another stupid offset ?
Old Feb 4, 2004 | 04:25 PM
Flipper's Avatar
Default another stupid offset ?
will a + 23 offset work on our xb
Old Feb 4, 2004 | 04:31 PM
bBted's Avatar
work perfectly on scion without modification! well...also depends on the width
matt has +25 offset looks perfect flush in the front...
Old Feb 4, 2004 | 04:33 PM
scionara's Avatar
18x8 with 23mm offset will work. If you go with the wider rim like 18x9 or 18x8.5, you will need to do some fender rollin'.
Old Feb 4, 2004 | 04:37 PM
Flipper's Avatar
its for these wheels they are 15's
Old Feb 4, 2004 | 04:39 PM
Flipper's Avatar
sorry.
Old Feb 4, 2004 | 05:14 PM
Opr8r's Avatar
Like Roger said, it also depends on the width. Take a 7" wide wheel for example... You'll probably need an offset below the 20's to get it totally flush. I'm still thinking anything in the 20's offset range is still too conservative. Again, it also depends on the width and what your goal is!
Peace,
m@
Old Feb 4, 2004 | 05:17 PM
HotBox's Avatar
what is fender rolling
Old Feb 4, 2004 | 05:26 PM
Opr8r's Avatar
It's basically the process of pushing the inside lip of the fender up... the goal being to gain more wheel/tire clearence.. and reduce (if not) eliminate rubbing issues.
Peace,
m@
xBrelease08
12
Feb 29, 2016 05:39 AM
CrowJenkins
Oct 9, 2015 10:47 PM
terrye
Sep 26, 2015 12:24 AM
xBrelease08
Sep 13, 2015 04:39 PM
BlingSlade
Sep 5, 2015 08:52 AM
