Tein vs. TRD
Old Feb 28, 2005 | 05:36 AM
nodnarb's Avatar
Default Tein vs. TRD
Which do you think is better or which do you prefer, Tein or TRD lowering springs?
Old Feb 28, 2005 | 05:54 AM
TheKnown's Avatar
tein s-techs
Old Feb 28, 2005 | 03:08 PM
nero_tC's Avatar
depends what kind of a drop you want and if u are willing to spend more for shocks or risking your OEM shocks blowing out faster.
Old Feb 28, 2005 | 03:25 PM
rhinonabox's Avatar
Tein S-techs (nuff said)
Old Feb 28, 2005 | 07:11 PM
aarontrini85's Avatar
im fine with my trd coils and with my trd sway bar by car handels great i have never driven any thing that fells this nice but then again i have never driven a bmw before so i dont know what excelent handling is
Old Feb 28, 2005 | 08:00 PM
rhinonabox's Avatar
How bout this?
Tein S-tech springs
TRD shocks/struts
Anyone running this setup? If so, how's the ride?
As for the original ??
The Tein S-tech spring will give you a better stance and smoother ride than the TRD springs
Old Feb 28, 2005 | 08:04 PM
BlkSandPrlTurbotC's Avatar
Tein S-Techs hands down
TRD doesn't belong on the tuner market
Old Feb 28, 2005 | 08:10 PM
scrap's Avatar
why doesn't TRD belong in the tuner market? if you knew about all the devlopments trd has made on the race track you would change your mind, it all trickles down into our cars someway or another. Just my thoughts.
Old Feb 28, 2005 | 08:16 PM
i think he is saying that becouse it is a factory option but look at the other companys factory options the stage 3 kit for the srt 4 is almost 355 hp and the nismo parts arent bad for the nissan's peaple just think that factory options arent "tuner" parts when they are some times better and safer pluss you get to keep your warrenty. just remember trd gets more r&d time then most other companys with the tc so i would trust them over any other's for most parts not all but most
Old Feb 28, 2005 | 08:25 PM
suby2scion's Avatar
Which springs are best for the stock struts as far as long tear wear and tear?
Old Feb 28, 2005 | 08:31 PM
TurboMe's Avatar
TRD
Old Mar 1, 2005 | 01:15 AM
leonDB's Avatar
TRD's... though if you're going to drop it you should change your struts too.
As for ride quality, here's a quote from a previous post on the spring rates that might help:
https://www.scionlife.com/forums/vie...ht=spring+rate
Originally Posted by tanlogic
FYI if any one cares on spring rate to compare stock vs TRD vs Tein S-Tech
Higher number = Stiffer Springs and I would assume stiffer ride
Front
Stock/TRD/Tein
25.5/29.8/35.3 N/mm
Rear
Stock/TRD/Tein
45/57/58.8 N/mm
It all boils down to what you want. If you want a slightly smoother ride and a good 1-1.25" drop, go with the TRD's. If you want to sit lower get the Teins. The spring rates aren't far so far off... I'd go with TRD's.
Old Mar 1, 2005 | 01:18 AM
leonDB's Avatar
Oh yeah, and trdsparks.com is also selling packages... they have TRD shock/strut packages, and even Hotchkis packages too. The hotchkis springs are supposed to drop to around 1.7-2" if you're interested.
Old Mar 1, 2005 | 02:59 AM
nero_tC's Avatar
Originally Posted by rhinonabox
How bout this?
Tein S-tech springs
TRD shocks/struts
How are the Tein S-Tech going to give you a smoother ride if the springs are stiffer than the TRD's? I'm guessing you mean a smoother ride on a perfectly flat road? I'm guessing you've driven in both?
Old Mar 1, 2005 | 05:36 AM
TougetC's Avatar
i suggest the TRD's, the Tein's actually tell u to expect about 5mm of sag. if u want an agressive track-ready spring, go with H&R. S-techs are for "looks". thats why theyre called super-"dress-up" springs. but the TRD's have been developed with Daily-drivers in mind. and the actual coils for TRD USA are manufactured by Eibach. theres my 2 cents, keep the tip.
Old Mar 1, 2005 | 07:54 AM
jermcruz's Avatar
anyone running H&R and have tried the TRD springs? how do they feel compared to each other?
Old Mar 1, 2005 | 08:06 AM
Somnambulated's Avatar
Assuming you care about your warranty, or not?
Old Mar 1, 2005 | 12:25 PM
nero_tC's Avatar
Good point, you keep full warranty with TRD.
jnesselroad
Sep 15, 2015 06:57 AM
Threequalseven
Aug 26, 2015 04:24 PM
Angelj85
Aug 18, 2015 01:27 AM
5N1PE5
Aug 3, 2015 11:25 AM
MadTitan
Jul 15, 2015 04:15 PM
