Changing Clutch Fluid
Old Sep 9, 2010 | 01:48 AM
gp1817's Avatar
Default Changing Clutch Fluid
Ok, i know the brake fluid and clutch fluid are shared,my question is,do we ever need to change the fluid if so how do we know it needs to be change,and How,
Old Sep 9, 2010 | 04:29 AM
Spicy_McHaggiz's Avatar
RESEARCH.
The clutch and brake fluid are the same as you stated, no need to call it clutch fluid. They run off the master cylinder and slave cylinder of the car. The only time it needs to be changed is IF the fluid appears dark and murky in color.
Old Sep 9, 2010 | 02:54 PM
tCb00b's Avatar
Originally Posted by Spicy_McHaggiz
RESEARCH.
Yes the hydraulic fluid reservoir is shared but due to the hygroscopic nature of brake fluid (has a tendency to absorb moisture) it is recommended to change it once every year or two for to maintain optimal brake performance. YMMV.
NinjaPilot
Feb 29, 2016 02:58 AM
zfxp
May 14, 2015 02:22 PM
pinkie1205
Mar 30, 2015 03:31 AM
gp1817
Mar 18, 2015 10:26 AM
mrsocks
Jan 20, 2015 01:29 PM
