Horn Install (Hella Supertone)
Old Mar 6, 2005 | 07:26 AM
CRxB's Avatar
Default Horn Install (Hella Supertone)
I wanted to change the dinky sounding horn we have in our tC so I got some Hella Twin Supertone (part# 85115) which is rated at 118db, one horn has a 300Hz low tone and 500Hz high tone Basically leaving a binging sound in your ear if you are right in front of it
Safety 1st - take out the ground from your battery and this is a D.I.Y. so don't blame me and I take no responsibilities...proceed at your own risk!
now on with the swap...
Open your hood and you will see you horn infront of the radiator. unclip harness and unbolt them using a 12mm socket or open wrench.
Comparison of the stock horn and the hella
Comparison of the stock horn and the hella mounted
Since the stock horn used the bracket as the grounding point so I also followed suit.
Now connect the 2 positive terminals and tap one of the horn harness(which is a positive trigger) for the relay. (solder and tape or crimp...doesn't really matter as long as the connection is good)
Ok since this horn has a high current draw it came with relay(highly recommended eventhough our factory horn is a postive trigger)
relay diagram care of www.the12volt.com
connect the following:
85 - Ground
86 - Positive Trigger from Horn Harness
30 - Constant 12volts(FUSED - I placed a 7.5amp)
87 - Positive Terminal from Hella Horn
87a - N/C(no connection)
Here's my wired up relay with my fuse and ground wire(use of split loom is optional but would look nice )
I mounted the relay on the bolt(10mm) holding down the airfilter box next to the battery
All you have to do now is connect the fused wire to the positive side of the battery, ground your relay( I used the same bolt where I mounted the relay ) and replace your ground from your battery.
picture of the finished install....
Honk away guys and wake up all those sleepy heads on the street
Old Mar 6, 2005 | 07:30 AM
mikochu's Avatar
Awesome! Thanks for the tutorial, Hubert. I bought some FIAMM Highway Blasters yesterday, but wasn't impressed with them. Would it be possible to record the new supertones...versus your xB's stock ones?
Thanks!
btw, added to the tech section. It'll be moved to the FAQ section in a week or so.
also...
^^^ looks like a robot or something... red eyes, blue mouth...
Old Mar 6, 2005 | 07:44 AM
CRxB's Avatar
Thanks!
your welcome man glad I can add some tech. as far as recording the sound I'll see if I can do it tom...I'm thinking I'll be infront of the car since my friends now walk behind my car everytime they see me in it but yeah these things blast!
i thought the same way when I say it cause I have red neons on the top grill and white on the bottom....
Old Mar 16, 2005 | 02:50 PM
JasonH's Avatar
Nice write-up! I'd like to hear the horns too, if you ever get around to recording them. I've thought of replacing mine, but I'm not sure if I just want to buy some new ones or go to a junkyard and see what I can find. Some old American cars have some serious horns!
Old Mar 16, 2005 | 05:34 PM
jrv2000's Avatar
if you could put up that recording of the horn that would be awsome
Old Mar 16, 2005 | 07:01 PM
ninjaKid's Avatar
oh hell yes . . . here comes the Dukes of Hazzard horn!!!!
Old Apr 12, 2005 | 12:18 PM
wedgiesaurus's Avatar
any update on the recording?
Old Apr 20, 2005 | 10:07 PM
Smokin's Avatar
bump
Old Jun 16, 2005 | 05:46 AM
CRxB's Avatar
*update* 06-15-05
sorry for the long delay but here is the sound clip from the hella's also thanks to matt(SGMgms) for recording the clip.
so here you go ..:Click Me"..
Hope this helps guys,
Old Jun 16, 2005 | 06:24 PM
Boricua's Avatar
Price?
The cheapest I found was $57 here: http://www.truckcustomizers.com/prod...4HLA261.1.html
Old Jun 19, 2005 | 09:49 AM
CRxB's Avatar
yeah they range from $60-$80 everywhere
Old Jun 19, 2005 | 06:17 PM
jrv2000's Avatar
could anyone hear the sound clip? For some reason when I tried to listen to it all I herd was silence.
Old Jun 19, 2005 | 11:25 PM
JasonH's Avatar
I heard it fine. Turn on your speakers, perhaps?
Old Jun 20, 2005 | 12:30 AM
jrv2000's Avatar
I got it to work on my other computer, one of mine is f ing up for some reason.
Old Jul 4, 2005 | 03:11 AM
sensay's Avatar
yup they sound like any other horn... probly just louder
Old Jul 24, 2005 | 01:55 AM
yesti's Avatar
i think the factory ones aren't that bad. at least they don't sound that 'F' note that american cars have. THOSE sound so wimpy, almost like like a loud whimper. My friend was being a butthead and blocked me so i blared the horn for a good 20 seconds at him and he said 'damn your horn is loud!' well i guess it's all relative...
Old Aug 21, 2005 | 02:47 PM
zyzyx6969's Avatar
Big Sky Scion
I have Camry horns, sound better than stock ones
plug and play
Old May 31, 2006 | 03:30 AM
cz3ch's Avatar
Try here:
http://www.lildevilmotorsports.com/h...rn-p-5346.html
Old May 31, 2006 | 03:35 AM
05-RS1's Avatar
nice diy!
Old May 31, 2006 | 04:00 AM
arrow519's Avatar
i'm thinkin of puttin a train horn on mine
www.hornblasters.com
prolly scare the ____ outta people havin' a little tC runnin aorund with a train horn attached
