Scion tC 2G ICE & Interior In-car entertainment and electronics...
Pioneer AVH-P4200dvd installed
Old Oct 29, 2010 | 10:53 PM
Ragingbull78's Avatar
Default Pioneer AVH-P4200dvd installed
Just installed the headunit in my tc2... works pretty good.. very nice unit... HD radio and Ipod video cable are on order...
As well as anyone else putting an aftermarket radio.. make sure you hook up a relay to power up the factory amp or the bottom speakers in the front will not work... if using a metra harness **obviously** power the blue wire with a full 12v's using a relay.. don't use the remote wire as there isn't enough to fully power it and it'll blow the wire... safer to use a relay
I post some pics of the amp turn on wire when i install the HD radio tuner and ipod when i have to take out the unit again... was very easy to install just need to power the amp to use all the speakers available in the car
FYI... the 3 speaker sizes in the door are Lower: 6x9, Mid 3", tweeter 1"
took the door apart to see why the speaker wasn't working
Old Oct 29, 2010 | 11:57 PM
jeremydoc's Avatar
looks clean
Old Oct 30, 2010 | 01:57 AM
GQQSE13's Avatar
looks good rage
Old Oct 30, 2010 | 02:35 AM
Superpickel's Avatar
At least with this model, you don't have to remove the shift **** and every other trim piece to get to the radio. All you have to do is pull off the bezel surrounding the radio and uplug the clock. So simple...
Old Oct 30, 2010 | 03:57 AM
1stOne's Avatar
It only takes 12V to turn the amp on. The remote turn on wire run to the metra "blue" wire for power antenna (aka the factory white/blue wire) and your done.
Don't need a relay.
Nice install though. How did you mount the dash trim kit? I had to use a little dab of hot glue behind mine. Silly Alpines wont accept the Metra kit nicely.
Old Nov 1, 2010 | 04:04 AM
Don't need a relay.
I find it easier and safer for myself to install a relay.. been in car electronics career for 12 years and just know better... personal preference i guess..
and yes.. did the same thing.. hot glue on the sides of the bezel to mount the gap covers... did the same thing when i had my xd to mount them...
also drilled out the dimples on the factory mounts to recess the radio just a little so it didn't stick out as much, looked much cleaner that way..
Old Nov 17, 2010 | 03:03 AM
kevinnz's Avatar
Hey guys i'm installing a sub for my friend in his 2011 TC. On the stock head unit, these two RCA out's are those sub outs?
Thanks
Old Feb 5, 2011 | 04:29 PM
asatar85's Avatar
hey rage any luck with those wiring pics?
Old Feb 5, 2011 | 06:08 PM
ninerbud's Avatar
How did you get the HD Radio to work? I was thinking about getting an aftermarket stereo but went with the Alpine Scion Upgrade for that reason alone. Is there a way to reuse what is there for the HD Radio, or did you just add an HD Radio install kit from Pioneer?
Old Feb 14, 2011 | 03:07 PM
KidJustin's Avatar
DaYUUM/Scion Evolution
would you mind posting (a link maybe?) the exact products you used for the install? like the harness or the mounting kit
also, does the steering wheel buttons still work? or did you have to install something else? like something from pac-audio?
Old Jul 1, 2011 | 02:46 PM
Nochi's Avatar
Default 11 scion tc
Watz up guys? Do any1 can help me out.I'm trying to hook up a pioneer double din radio on a 11 tc. I just hook up the power and the speakers wires to see if itbwork but it seems that rear speaker works and right side front the middle speaker work but the rest of the front speaker doesn't work. Any suggestion. Thnx
Old Jul 2, 2011 | 12:27 PM
b52hDUNN's Avatar
You have your wires mixed up on the harness.
Old Jul 5, 2011 | 06:15 PM
devanb3's Avatar
so i just have one quick question what exactly needs to be wired in order to keep the bottom 6x9s working i installed my old kenwood kdc-x994 and had to unplug the cars stock amp because it kept sending the unit into protect mode im guessing you have figured out how to get around that or did you just pull the door panel off and run wires from the 3s to the 6x9s thanks
Old Jul 5, 2011 | 06:43 PM
KidJustin's Avatar
bottom speakers are powered by the amp
...for the speakrs to be on the amp has to be on
the wire that turns on the amp is blue....that wire has to be connected to the harness of the aftermarket HU...blue to blue (usually)
Old Jul 5, 2011 | 08:13 PM
Rotz's Avatar
I assume you're using a metra harness. Is the solid blue "Powered Antenna" wire that needs 12v switched to turn on the factory amp.
Old Jul 9, 2011 | 10:33 PM
javithekid069's Avatar
got my avh-p3300bt installed, would've preferred 4200 but didn't want to spend so much and got mine for 450 with 2yrs of product replacement warranty on best buy.
the thing is, I bought the axxess aswc kit but I did not want to splice any cables on the stock wiring, also, couldn't find how to, the cables are not the same color and there's no diagram on how to. How did you manage to do it? Is there any harness for it, I've seen them for other toyotas. Any help will be appreciated. Thanks
BTW yours looks awesome..
Old Jul 9, 2011 | 10:42 PM
Here it is...
Old Jul 10, 2011 | 07:03 AM
KidJustin's Avatar
general manual
http://contentdocs.installernet.com/...duct/23230.pdf
specific for our tC2
http://contentdocs.installernet.com/...icle/10957.pdf
for the aswc
wire harness i used (to install the radio and spliced the aswc to...no splicing to factory)
http://cgi.ebay.com/ebaymotors/_W0QQ...8Q26Q5ffviQ3d1
check my build thread for how i installed mine...post or PM for any additional questions
Old Jul 11, 2011 | 01:15 AM
zaksturbo's Avatar
where did u come across one with a push button start, i work at a dealer and have looked but cant find the part..
Old Jul 11, 2011 | 03:47 AM
Zaks, i'm from puerto rico and here its a standard option, like the rear wiper and bluetooth too
Dont know why but lucky me, because the keyless entry is super awesome, i never ever take the key (beeper) out of my pocket!
