carpet inside car gets wet..ac problem?
Old Dec 28, 2010 | 04:12 PM
XIEmperorIX's Avatar
Default carpet inside car gets wet..ac problem?
So I think I may have a clogged AC or some other AC related issue...carpet in my car has been getting wet if the car sits for a few hours and a LOT of condensation builds up on my windows also..takes like 15 min to defrost.
Anyone had this problem? I was thinking about taking it in to get the AC flushed but I was curious if anyone else has any insight on if it could be something else.
My tC is only 4 years old and it wets itself..-_-...
Old Dec 29, 2010 | 07:19 AM
sciontc_mich's Avatar
if it's just water and not coolant. Heater cores that crack can leak like that and cause moisture inside the car as well. Have you checked the coolant level in the reservoir? Is it at the same level?
If it's not coolant and just water, it's probably the a/c drain hose. do you hear a sloshing noise around the glovebox area too?? It could still be water inside the a/c box and chances are the rubber drain hose is blocked. easy fix, yes others have had this, not all but some have had it.
Old Dec 29, 2010 | 08:40 AM
It doesn't smell or look like coolant..took a water vac to it and it was just water. How do I go about checking out the drain hose?
Old Dec 29, 2010 | 11:54 PM
glad to hear it was just water. The drain hose is in the footwell of the passenger side, underneath the glove box. follow from the a/c box down, you'll find a hose there in the floor by the carpeting. have to pull the carpeting back and then you can wiggle the hose out and clean it out. The hose goes to the outside to drip the water condesation. hope that explains it better
Old Dec 30, 2010 | 01:22 AM
Thanks..sounds simple enough..I hope lol I'll take a look at it next week..set aside a day to do some work to the tC so I'll add that to the list if I can
Old Jan 1, 2011 | 06:29 PM
gtfourtc's Avatar
yeah definitely sound like a clogged condensation drain tube.
Old Jan 2, 2011 | 02:26 AM
sw09's Avatar
or when you have the car up look for the hose and clean it from under the car
Old Jan 2, 2011 | 08:49 PM
just occurred to me..how to I check if the condensation tube is indeed plugged up and how do I go about unclogging it?
Jordly221
Feb 13, 2019 05:29 PM
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
Joeynenj
Nov 25, 2014 05:29 AM
randode
44
Jun 29, 2004 04:19 PM
