Stock steel wheel weight
Old Mar 10, 2005 | 05:22 PM
mikem53's Avatar
Default Stock steel wheel weight
A couple of weeks ago, I had a flat that was not repairable. So I needed a new tire with only 450 miles on it...
I noticed how fricken heavy the stock wheels are... Does anyone know the weight of them?
I found some alloy wheels, same size that weigh about 16.5 pounds. If this is a significant savings over the steel , I think I will have to get them....
thanks in advance.
mike
Old Mar 11, 2005 | 01:16 AM
Ducman69's Avatar
Sorry I don't have the answer, here's a free bump though. ;)
Out of curiosity, which wheels were you looking at? 16.5 lbs isn't bad. Have you seen these suckers though on tirerack? Only 10.6 lbs, hunfitty bucks, and would be a wild accent color on a white xB. They also have a more subtle silver and light gray, but I can't say anything to the quality of that manf. *shrugs*
Old Mar 11, 2005 | 05:24 PM
mikem53's Avatar
Thanks for the bump.. I was looking at the Borbet wheels. Found them on tirerack. I am going to go with the stock size, so that helps keep the weight down. They look much nicer and I am assuming they are much lighter... I am hoping someone ha this info on here..
Old Sep 2, 2005 | 02:29 AM
Texas_is_hot's Avatar
I would also like to know this.
I'm looking at some 16x7 alloys that weigh 14.5lbs.
or these 15x6.5 ones at 12 lbs
Old Sep 2, 2005 | 04:16 AM
ScionPsyche's Avatar
The stock wheels and hubcaps weigh 20lb. I got these Konig Rewinds in 15X7 - they weigh 14lb ea:
Old Sep 2, 2005 | 02:15 PM
Digger's Avatar
Dang, I've been looking and looking for a set of wheels that hit me just right and these Konigs just did it. I plan to slam the box this weekend 1.5" so I'll start searching for the best place to get wheels like those.
Old Sep 3, 2005 | 03:31 AM
UnFocused's Avatar
from my measurements the stock combo was 21 LBS , and so was the TRD 18"s that I replaced them with...
kleecker
May 22, 2016 06:10 AM
mischman
Jan 14, 2015 06:07 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
TJ
10
Apr 15, 2006 05:12 PM
sithscripter
Oct 5, 2003 06:54 PM
