spark plug removal
Old Feb 2, 2011 | 07:07 PM
BigJohnXa's Avatar
Default spark plug removal
I have a misfire in cylinder 1 and im changing out the plugs but my socket doesnt fit down in the cylinder but i got all the other ones out what can i do
Old Feb 2, 2011 | 07:11 PM
mijos87's Avatar
if it fit down the other ones it should go down the first one.... take a pic maybe it would help us help you out more
Old Feb 2, 2011 | 10:35 PM
BigJohnXa's Avatar
i found the problem a eubber piece from the coil is stuck down there so i need to figure out how to get that out now
Old Feb 3, 2011 | 02:07 AM
Bertmagik's Avatar
go to anywhere that sells anything automotive... napa, autozone, whatever... they sell these neat little parts retrievers. usually long and skinny and flexible with a claw on the end, some have lights too which are helpful. its a cheap tool that comes in handy more than you might think. good luck!
Old Feb 3, 2011 | 05:22 AM
mijos87's Avatar
second that motion, deffinitly a life saver at times that lil claw is
Old Feb 5, 2011 | 04:39 AM
VIP_CAMO's Avatar
Big Sky Scion
could this be your issue with your other problem?might want to have your engine compression checked
Old Feb 5, 2011 | 02:59 PM
BigJohnXa's Avatar
yeah im gonna check that i gotta pick up a compression tester today do you know what our compression should be at?
Old Feb 8, 2011 | 06:31 AM
Bertmagik's Avatar
prolly around 9:1... thats pretty baseline for most vehicles
Old Feb 8, 2011 | 03:19 PM
BigJohnXa's Avatar
i fixed the problem it was a bad vacuum line
Old Feb 8, 2011 | 07:41 PM
DJ_SpaRky's Avatar
Not for these, xA/xB1 1NZ-FE have a 10.5:1 ratio
Compression:
Standard compression pressure 1,471 kPa (15.0 kgf/cm2, 213 psi)
Minimum pressure 1,079 kPa (11.0 kgf/cm2, 156 psi)
Difference between each cylinder 98 kPa (1.0 kgf/cm2, 14 psi)
Old Feb 10, 2011 | 02:16 AM
Bertmagik's Avatar
my bad. didnt mean to throw out false info
RY_TC07
Jul 18, 2017 05:18 PM
kleecker
Jul 11, 2015 09:39 PM
nightfox915
Apr 10, 2015 01:28 AM
daniinpitt
Apr 4, 2015 08:07 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
