WR Breather filter?
Old Mar 11, 2005 | 08:23 PM
coppermine18's Avatar
Default WR Breather filter?
Got my secret weapon in, sounds sick I love it!
What about the breather filter? Should I install it? If so... What is the proper way? Thanks!
Paul
Old Feb 17, 2009 | 12:49 AM
ksrturbo's Avatar
Ronin Scion
bump...
i got the same ?
Old Feb 17, 2009 | 12:53 AM
rallying_the_scion's Avatar
TOCC
wow...revival from way dead..thats a breather filter?
Old Feb 18, 2009 | 01:01 AM
WRLEO's Avatar
Your supposed to put the breather filter on the valve cover crank case vent.. the hose that goes to the intake.. Your replacing that hose, so the fumes from the crank case breathes into the atmosphere..
The nipple on the pipe gets capped of then..
Although i suggest using a oil catch tank at all times.. this works also..
This keeps carbon buildup from the fumes from the crank case from building up on the inside of the throttle body.
Old Feb 18, 2009 | 01:08 AM
rosedaleny806's Avatar
4 year bumps are awesome
Old Feb 18, 2009 | 01:11 AM
Carlanga's Avatar
at least someone answered the question
Old Feb 18, 2009 | 01:13 AM
ksrturbo's Avatar
Ronin Scion
do you think i should use the breather or ill do better with out it
Old Feb 18, 2009 | 01:14 AM
ack154's Avatar
Even though this is 4 years old... it's kind of how it's supposed to work. This guy probably used the search and found this and instead of creating a new thread (thus cluttering the search results even further) and someone actually answered it.
Old Feb 18, 2009 | 03:31 AM
highvoltage1's Avatar
Wow the search but worked!! Searching FTW!!
Old Feb 18, 2009 | 03:37 AM
WRLEO's Avatar
I would use the breather.. because im sure you dont wanna buy a oil catch tank if you already have a breather filter that does the same thing as the tank..
Old Feb 18, 2009 | 03:50 AM
Well isnt the Catch tank better than the breather?
Old Feb 18, 2009 | 06:05 AM
WRLEO's Avatar
If he wanna spend the cheddar, yes its better but he already has abreather filter ... no need to waste it..
Old Feb 18, 2009 | 06:08 PM
Ok just wanted to clear that up for myslef!
Old Feb 18, 2009 | 06:16 PM
ksrturbo's Avatar
Ronin Scion
whats the proper way to install the breather cuz someone told me that i needed two of them but i dont think thats true any pics of the way it should look installed would help.
Old Feb 18, 2009 | 11:35 PM
I believe you just hook up the breather to the attached lil pipe comign off the valve cover or attach the breather to the end of the stock rubber hose thing coming off the valve cover and there ya go. But If you can do it the first way that would be best as the breather would be flopping around the other way.
Old Feb 23, 2009 | 04:17 PM
ippskidder's Avatar
1UP Crew
Since we're on the subject ^^.
Where does the catch can go exactly??
Right now I have it between the hose on the back of the valve cover going to the back of the intake manifold, and I have just a little breather filter on the side of the valve cover.
OR
I've also heard that people, plug the hole on the back of the intake manifold. Then put the catch can between, the hole on the back of the valve cover, and the hole on the side (driver's side) of the valve cover.
Oh and i'm boosted.
Thoughts?
Old Feb 23, 2009 | 10:12 PM
It goes on the front hose off the valve cover and then back to the intake not the hose on the back of the valve cover that goes to the Intake Manifold! Cause the one on the back isnt for oil its for vapors. Its got a special valve called a PCV i forget what it stands for.
Old Feb 24, 2009 | 01:36 PM
ippskidder's Avatar
1UP Crew
positive crank ventilation, if i'm not mistaken.
Yea I was reading about it all day yesterday. ^^
Some people even use 2 catch cans.
I'm still researching it though.
Old Feb 24, 2009 | 09:31 PM
Yea i think thats what to dual catch can is for but i usually see the single being used for the purpose i stated. The reason is that you get oil coming out of that hose unlike the way you have it where it is vapor. Thats why u get build up in your intake and on your throttlebody sometime. Thats why i suggest the way i stated.
Old Apr 28, 2010 | 07:07 PM
Irish_tc_518's Avatar
bump
so the breather filter and the catch can both attach to the valve cover vent?
and breather exhausts to the engine bay while the catch can filters before sending it to the intake?
what is the advantage if the intake sucking out the fumes?
