Forjworks 2011 Scion XB Air ride systems front struts.
Side Skirts are just barely scraping the ground
Marshalls Gen 2 XB "First Gen 2 XB on Bags" with its new look and newly designed prototype struts.
Order online
Forjworks Air Ride Systems Gen 2 2008 and up Scion XB kits are now for sale one out site.. You can just click and order directly online!
http://www.forjworks.com/Product.asp...CategoryId=40#
Ok guys we finally at www.forjworks.com designed our AIR STRUTS SYSTEM for the gen 2 Scion XB that is just as low or even lower than any kit that is out on the market. It will be ready for retail soon.
With months of R&D work on these struts this kit will get you LOW! our bag perch placement gives you optimized lowest possible drop as well as a smooth ride. CNC Machined mounts for exact fitment that is not loose, so this eleminates rattles. Our upper plates that mount at the top of the bags have recessed holes and uses tappered bolts so the strut brearing is as low as possible.
It is designed as two types of kits.
1. DIY kit. It comes with all the mounts and bags. Our Mounts are made to fit the strut body and shafts. You will use your OEM strut with slight modification "cutting of the spring perch" and welding of the FORJWORKS AIR SYSTEM Mount to the sway bar mount, so there is no need to worry about welding onto the body of the strut housing.
2. Bolt on strut set up
All of our kits use Universal Air AERO SPORT STRUT BAGS.
All mounts are CNC machined for precise fitment
This set up will work with 19 inch wheels!
When you need slam www.forjworks.com has what your looking for.
Our top mounts are designed with counter sunk bolts to give you optimized bearing clearance.
Notice other kits the perch mount is made to be universal. notice how big the center hole is.
Forjworks Air Systems Mounts are CNC Machined to extact fitment
here is the pricing on our full kits.. our kits are the lowest in the market for the 2nd gen XB.
DIY Kits using our state of the art CNC cut strut brackets. Use you exisiting Struts.
Forjworks Air Systems Front bag Bracket
Forjworks Air Systems Rear bag Bracket
2 UAS AERO SPORT strut bags
2 UAS AIr house 2 bags
VIAIR 380 COmpressor
4 Gal Aluminum Tank
Water Trap
2 Air Switches
80 amp heavy duty Soleniod
Pressure Switch 200 psi
Line Fitting Wire kit.
1479.00
Optional but required Dakota Digital Gauges but highly required
$359.95
Optional Basic install "Hawaii only"
$1000.00
Plus shipping
bolt on Kits using our state of the art CNC cut strut brackets mounted on Tokico Blues or KYB depending on application
Tokico Blue struts (FR) and shocks (RR)
4 Gal Aluminum Tank
Water Trap
2 Air Switches
1859.00
$359.95
$1000.00
Plus shipping
NOTE: WE do not use push to connect fittings like all the other kits in the market. We work in this industry so long and deal with tons of fittings on a daily baisis and push to connect is a fitting that doesnt last becuase of rubber O Rings inside of them used to seal. As we all know rubber get hard and birttle and starts to leak. All of our kits come with DOT Compression type fittings that are by far the best in the industry and will last.
Here is an cut away of a push to connect fitting.
4 Gal Aluminum Tank
Water Trap
2 Air Switches
1479.00
$359.95
$1000.00
Plus shipping
4 Gal Aluminum Tank
Water Trap
2 Air Switches
1859.00
$359.95
$1000.00
Plus shipping
WE only use CNC to cut all of our brackets. So everything is precise!
IF you have any questions please Email info@forjworks.com or call text 808 7532938 and our customer serivce staff will get back with you fast!
Sample of what we do.
Order online!
Just wanted to point out that DOT PTC ( Push to Connect ) fittings are JUST as reliable as compression. Compression fittings use plastic ferrals that are no stronger then the rubber orings inside the PTC fittings. This is all purely personal preference.
Hydraulics also use rubber o rings, and I have a press at work that will do 350 tons of pressure that uses rubber o rings to sell the rams. Just some FYI.
Do you sell just the brackets for the struts, or just a pair of struts? I've asked this a few times now without a response?
Not going to argue the point and debate and waste my time on compression and PTC.. I know there are fans of those so be it.. we use only the best fittings compression.
So what you are saying that rubber dont wear out.. Hdy press uses special oring seals to seal that amount of pressure.. im usre its not just an oring. becuase i have repaired those cyl before
Pork sorry the only thing you asked here is if that cut away fitting was a DOT fitting.
The brackets are up on the site.
http://www.forjworks.com/Air-Strut-B...-Set-P124.aspx
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
JM Auto Racing
Dec 19, 2014 06:36 PM
minter66
Dec 15, 2014 01:45 PM
