Hotchkis rear springs question?
Old Mar 13, 2011 | 10:51 PM
Roller_Toaster's Avatar
Default Hotchkis rear springs question?
Just curious...I just installed my hotchkis springs yesterday, but the rear seems much higher than the front. Could I have installed the rear springs upside down?
I put the rear springs on with the larger diameter coils on the bottom, and the smaller up top.
Maybe they just need to settle?
Old Mar 14, 2011 | 05:25 PM
76 views and nada?
Old Mar 14, 2011 | 05:43 PM
xseveredveganx's Avatar
Utah Scions
I have the Hotchkis springs, but never had an issue like this. If you can read "Hotchkis" and the part number, then they're probably right side up.
Pictures would certainly help.
Old Mar 14, 2011 | 07:33 PM
just went out to snap a picture and realized that the right rear spring must have somehow slipped off of the upper perch. Im going to run by a nearby muffler shop and see if they will let me take out the rear shock bolts and put it where its supposed to go.
Old Mar 14, 2011 | 07:36 PM
jrincon17's Avatar
Use a jack takes 10 minutes
Old Mar 14, 2011 | 07:53 PM
Ok, everything is better now. I must have forgotten to make sure the RR spring was fitted into the upper perch.
Old Mar 14, 2011 | 07:54 PM
Normally I would, but its raining buckets here.
Last edited by Roller_Toaster; Mar 14, 2011 at 07:59 PM. Reason: Comma placement fail.
Old Mar 14, 2011 | 08:06 PM
Utah Scions
So everything's golden?
Old Mar 14, 2011 | 08:09 PM
As a goose egg! Rear now sits lower also :D
I didn't really take into account HOW low these springs are...they couldn't even fit the posts for the lift under it
Old Mar 14, 2011 | 08:10 PM
jrincon17's Avatar
COOL !
Old Mar 14, 2011 | 08:23 PM
Utah Scions
Nope. I have been on my Hotchkis TVS since it was first released.
My TRD 19's raised me up a little, though.
Old Mar 14, 2011 | 08:27 PM
vegan, thanks for the pic request! If you hadn't, I never would have laid on my side on the wet ground to get a picture, and never would have noticed the spring.
Old Mar 16, 2011 | 12:04 PM
sooo...they might actually be upside down.
Thats just embarassing. I didn't even check to see which way "hotchkis" was pointing.
Heading to the rents house to flip them.....:facepalm:
Old Mar 16, 2011 | 01:47 PM
jrincon17's Avatar
lol face palm !
Old Mar 16, 2011 | 05:30 PM
After an enormous fail on my part, I flipped the springs over in about 10 minutes. It immediately felt even BETTER, and is now a 2 finger gap. Muuuuch better.
Old Mar 16, 2011 | 06:19 PM
Utah Scions
It happens, bro! I know I was embarassed when I installed my front sway bar upside down. Face palm indeed.
Not WINNING!!!
TotalChaos
13
Feb 4, 2015 10:24 PM
kleecker
Jan 9, 2015 02:26 PM
TheTripleC
Jan 4, 2015 06:46 PM
fluxingnation
Dec 26, 2014 04:28 PM
deathcabforme
Oct 29, 2003 05:23 AM
