Auxillary Plug For Radio Not Working
Old Mar 15, 2011 | 03:54 AM
graybox's Avatar
Default Auxillary Plug For Radio Not Working
I am the new owner of a 2006 Xb and so far I love it. The only problem I found is that when I plug my ipod into the auxillary receptical and push the auxillary button on the radio controls, nothing happens. I have tried several different cords and that does not seem to be the problem.
Is this a common problem? How should I start trying to fix it?. I am definitely not handy and if it is not a simple trouble shooting solution, I may be out of luck without resorting to a dealer or sound company.
I am supposed to have a year of warranty left. Would this likely be covered under the warranty?
I will appreciate any suggestions. Thanks.
Old Mar 15, 2011 | 06:17 AM
jkhoury's Avatar
same happened wid me. dealership said the aux part of the radio wasnt connected so they connected it for free
Old Mar 15, 2011 | 12:51 PM
graybox's Avatar
I hope my fix is as simple as that. I will check with the dealer. Only problem is that where I bought the car is about an hour away. Not too convenient to be running back and forth. If it is under warranty, perhaps a local dealer can check it. I will try to clarify that.
Old Mar 18, 2011 | 08:03 PM
lancer's Avatar
could be a bad solder job on the wire harnest if you have a aftermarket radio. i have the eclipse AVN6620 direct plug in to factory harness
Old Mar 23, 2011 | 10:19 AM
whiitlcj1's Avatar
If I remember correctly: take the air/con ***** off. Unscrew those screws. Pop off the console facia. Pull the radio out (I believe 10mil). It will only come out about 7 inches so put your tiny hands on. See if the harness is fully connected. If there is something loose, don't pull it out. If it's broke you might break it even worse. Just push it in further by grasping the plastic and not the wires.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
O5_TRD_tC
Feb 18, 2015 09:01 PM
clickclickw00t
Feb 18, 2015 08:57 PM
MaxPower
Oct 22, 2003 09:22 PM
