Regional - Lonestar: DFW Metro Dallas / Fort Worth Metroplitan Area
Headlight swap
Old Mar 24, 2011 | 11:11 PM
XRACER76's Avatar
Default Headlight swap
Dumb question but will 2010 Halogen headlights fit on a 2005 Non Halogen headlight and vice versa? This is for a TC.
Old Mar 24, 2011 | 11:16 PM
XRACER76's Avatar
Basically a headlight swap if that makes better sense.
Old Mar 25, 2011 | 01:21 AM
O5_TRD_tC's Avatar
yes, but it uses H11 instead of 9006 bulbs
Old Mar 25, 2011 | 01:25 AM
XRACER76's Avatar
So basically I would need to switch the bulbs out or does it require more then that? Do you have to change the wiring harness at all?
Old Mar 25, 2011 | 05:11 AM
SquallLHeart's Avatar
you need to change the wiring harness. h11 and 9006 are two different sizes.
and fyi, oem 2007 and below are all halogen.. so i'm not sure what you are talking about with the "non halogen" comment.
Old Mar 25, 2011 | 12:12 PM
XRACER76's Avatar
Good point. As you can tell I'm very versed in this subject. So it's a diferent bulb size and harness. Is it hard to change the harness out? I'm assuming it requires cutting the wires?
Old Mar 29, 2011 | 03:11 AM
xdejablu3x's Avatar
Really? I thought you just need to change the bulbs to the correct size when swapping to the projector headlights?
MadTitan
Jun 16, 2016 06:23 PM
sabot7726
Apr 28, 2016 08:20 AM
mischman
Sep 15, 2015 03:38 PM
carid
Scion tC 2G Aero & Exterior
Sep 1, 2015 09:08 PM
umnitza
Jul 25, 2015 07:54 PM
