MAJOR brake pad rust after winter storage
Old Mar 14, 2005 | 11:25 PM
ScionTcLuva's Avatar
Default MAJOR brake pad rust after winter storage
Hi yall just need a lil advice. I Bought my tC back in JULY of last year, i love it Well I stored it outside my home for the winter in Western NY. I took all the basic winter prep steps.
The only thing that concerns me is the EXTENSIVE rust on the Rotor pads. This is my first new car and I just wanna do it right. Just curious to everyone's thoughts on this. Do I need to remove the rotors and have them slightly resurfaced? The pads are completely covered in rust and when i run my finger over them it is very rough. Any advice is appreciated as always guys! Thanks
Old Mar 14, 2005 | 11:33 PM
dex's Avatar
dex
hello fellow WNYer. you should just try to clean em up yourself with some scotchbrite.
Old Mar 15, 2005 | 12:29 AM
xnevergiveinx's Avatar
if it was me, i would just drive around and use the brakes, it'll strip that crap right off for you. your going to have a hard time getting the inside by hand, unless you take the rotors off. i think you'll be ok
Old Mar 15, 2005 | 04:50 AM
You don't think just driving the rust off will pit up the rotors? Thats about my only concern really hate to ruin almost new rotors. Many apologies if I seem to paranoid LOL just tryin to be cautious. Thanks all
Old Mar 15, 2005 | 04:59 AM
ader's Avatar
haha dude, i had the same problem. i was going insane seeing my rotors were rusted! lol but actually if u drive it around like u normally would, the rust would get scrapped off and ur rotors will be just fine. hope that helps fellow paranoid tC fanatic
Old Mar 15, 2005 | 05:24 AM
TurboMe's Avatar
yep thats works! I noticed that I had rust on my rotors and thought about the pain it would be to clean them but after I got home from school it was gone.
Old Mar 15, 2005 | 06:31 AM
Thanks a million all! Will do just that. See yall on the NY streets!
Old Mar 16, 2005 | 04:43 PM
Kurve's Avatar
yeah thats normal if ur around a lot of water and dont drive the car a lot ...but driving it will remove all that ..
Old Mar 16, 2005 | 05:22 PM
Pimpe_Ok's Avatar
Utah Scions
if your rotters do get messed up rimember u are still under worenty and that is coverd!!!
Old Mar 17, 2005 | 01:15 AM
CBSIMONSEZ's Avatar
This is a wearable part, and is not covered for wear, nor rust. Just like your belts, wipers, and tires are not under manufactors warrenty. * i know that tires are usually covered under the tire maker.
The rust build up is normal. Drive regularly and see what happens after a few stops. If upon closer look you see that the rotor is pitted, then you should have the rotors resurfaced to get them out.
Old Mar 17, 2005 | 02:04 AM
dgHotLava's Avatar
its that simple! now, go drive that thing.
be easy on the brake pedal for the first few stops. it might be a little grabby.
if it was real, real, real bad you might get a pulse in the prake pedal...
if you do, get the rotors cut, but i doubt that this will be an issue...
Old Mar 17, 2005 | 02:39 AM
pkoule's Avatar
Won't hurt your brake pads either.
Old Mar 17, 2005 | 05:03 AM
if you don't want it happening again, you should try spraying down your rotors with wd40 before you put the car in storage, it should help to prevent rust. just be a little careful when you take it out, give it plenty of distance to stop for the first couple of times
Old Mar 17, 2005 | 05:07 AM
TurboMe's Avatar
^ thats not a good idea lol
Old Mar 17, 2005 | 01:32 PM
dgHotLava's Avatar
VERY BAD IDEA!!!
Old Mar 17, 2005 | 02:56 PM
Pimpe_Ok's Avatar
Utah Scions
OMG dam basterds i see now how they mack there money saying is a waeribal part!!!! down with the man!!
Old Mar 17, 2005 | 03:23 PM
Streeter's Avatar
VERY BAD IDEA!!!
I did this on my Huffy when I was a kid. Take it from me. BAD IDEA.
I was the fastest kid on a bike, but certainly not the "fastest"
cquencebrakes
Jun 23, 2015 09:42 PM
PrettySenshi
Apr 13, 2015 05:21 PM
mikochu
Autosports & Technique
57
May 25, 2005 03:07 PM
George
25
Aug 31, 2004 05:38 PM
kdanie
10
Jan 25, 2004 07:08 PM
