Scion xB 2nd-Gen Forced Induction Turbo and supercharger applications...
problem on my turbo wagon...help
Old Jun 8, 2011 | 04:34 AM
matrix_XB's Avatar
Default problem on my turbo wagon...help
I just do my xb turbo and when I went up in lights traction control and I can not activate this is common?
Old Jun 8, 2011 | 04:37 AM
sp2's Avatar
sp2
Defined3
Sorry but write this more clearly and detailed or no one will know can help.
Old Jun 8, 2011 | 04:54 AM
Pasquale's Avatar
exactly what is the car doing? it wont turn over...wont pull out of 2500rpm's so on and so on?
Old Jun 8, 2011 | 05:53 AM
matrix_XB's Avatar
what happens is that since the turbo I always kept the lights turned on traction control and no way to remove....
excuse my english, you have not mastered very well'm puerto rico
Old Jun 8, 2011 | 08:08 AM
sp2's Avatar
sp2
Defined3
You have check engine light too?
When ever i get a check engine light the vsc traction light turns on too
Have you tried a code reader and see what codes and or to clear them if any?
Old Jun 8, 2011 | 01:46 PM
matrix_XB's Avatar
if the check engine is on but I did not take to see that codes given, any solution to this?
Old Jun 8, 2011 | 06:11 PM
sp2's Avatar
sp2
Defined3
I bought a code reader from auto part store or you could order online to see what code or codes your running then you can delete them. So you can turn off lights.
You should figure out soon what codes so dont mess up car.
Old Jun 8, 2011 | 07:01 PM
ScionFred's Avatar
When the ECU sets an active CEL it also disables TC and VSC. Yes, this is very common when boosting. When I first turbocharged my XB I had the same thing, usually a P0101 (MAF out of range). I eventually solved the CEL issue with a custom intake pipe.
The first thing you need to do is get a scan tool so you can read the active and pending CEL codes. Next you can post them with all details of your turbo setup and we may be able to help you sort this out.
Old Jun 9, 2011 | 02:27 AM
matrix_XB's Avatar
Thanks..
Old Jun 9, 2011 | 04:20 AM
ScionFred's Avatar
How about some pics?
Old Jun 9, 2011 | 02:16 PM
matrix_XB's Avatar
today to my surprise was to mount the Fuel pump and when I Gadolin account of manufactures is smaller than the walbro and the tank is plastic ... any suggestions for this?
Old Jun 9, 2011 | 05:12 PM
ScionFred's Avatar
You'll have to modify the plastic pump housing to fit the Walbro.
my06tc
Jun 25, 2015 12:18 AM
mav261
Mar 24, 2015 01:19 AM
skruff
Scion tC 1G Wheel & Tire
Mar 16, 2015 06:16 PM
darkshadowofxdeath
Feb 11, 2015 05:38 PM
PTUNING
Dec 11, 2014 08:09 PM
