Question about emblem removal (xB)
Old Mar 19, 2005 | 06:03 AM
scott-'s Avatar
Default Question about emblem removal (xB)
how long would i use the blow dryer on the emblem to heat it up?
Old Mar 19, 2005 | 06:13 AM
pharynx's Avatar
Get it hot enough so it's almost burn to the touch, but generally no longer than a minute at a time. Remember, it just needs to be hot enough to peel the thing off, not the gummy residue - that can be removed with the goo gone and a slow back-and-forth rolling motion with your thumb/index finger.
Help this helps.
Old Mar 19, 2005 | 08:05 AM
spongebBox's Avatar
yeh..and i suggest going in circles with te blowdryer upon the emblem..and not leaving it directly upon the emblem. this way you can thoroughly heat up the glue in its entirety. then use the floss or fishing line to cut the emblem off, and the goo gone to remove the remainin glue as 'pharynx' mentioned. you should find it easy.
Old Mar 19, 2005 | 12:10 PM
scott-'s Avatar
thank you for the help
Old Mar 19, 2005 | 01:29 PM
ssdm7683's Avatar
I live in Texas...i just did mine on a HOT summer day !
Old Mar 19, 2005 | 02:02 PM
scott-'s Avatar
hehehe i was thinking about doing that..but its suppose to rain this weekend
Old Mar 19, 2005 | 02:45 PM
DTurnbull's Avatar
I don't think you even need one. I took mine off on a cool day with a piece of dental floss.
Old Mar 19, 2005 | 02:56 PM
Eddieg's Avatar
I used fishing line and a heat gun. Floss melts to fast when using the heat gun or hair dryer. Just take you time, and you will be very happy with your results!
Old Mar 19, 2005 | 03:57 PM
TheDanger's Avatar
I live in Florida and did the same...but ive done my girlfriends and a good friends with a blow dryer. Be careful to only use your thumb in removing the goop. Trying to peel can result in marks all over.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
