Input needed
Old Aug 19, 2011 | 05:57 AM
mike93civic's Avatar
Default Input needed
I'm looking to improve the xB's handling. I was wondering if anyone could shed some insight on which way to go. I'm currently considering either an H-brace, possibly from Tanabe, or going with a rear sway bar kit. Any input would be appreciated, particularly those with first hand experience of said products.
Old Aug 19, 2011 | 11:02 AM
criminaltc's Avatar
This is about all you can do:
Strut bar
Front sway bar
Rear sway bar
Coilovers/Springs
Wider tires
Bam, there you go
Old Aug 19, 2011 | 11:03 AM
criminaltc's Avatar
You can replace the struts and shocks as well.
There's a lot of money in suspension. But there's also a lot of options. Have fun.
Old Aug 19, 2011 | 02:51 PM
Ometta's Avatar
Cheapest way to go would be to add a rear sway bar and you can install it yourself. Don't add a front sway bar cause in my opinion they don't do crap.
Old Aug 19, 2011 | 03:19 PM
criminaltc's Avatar
Yes, the rear sway bar and springs are probably the best and cheapest start to any suspension job and it is very effective, you'll notice instantly.
after that go for the full shebang, coilovers on new shock/struts with bushings, camber, arm bars, dampers, you name it, it will help. autox here we come!
Old Aug 19, 2011 | 03:34 PM
jcXB's Avatar
It also depends on your budget. Here's how I went about my xB suspension upgrades (in order):
-TRD lowering springs ($120),
-1/2" rear hub spacers ($50 ebay)
-TRD Rear Sway bar ($90 new ebay)
-Switched to 17x7 Volk wheels with 205/45/17 tires from stock 15 steelies 185/60/15 tires (~$1400)
-Switched to Tein S-tech Lowering springs 3 weeks ago ($150), TRD springs will be posted for sale soon.
-Switched to TRD Waydoo Sportivo Shocks/struts
-Energy Suspension front sway bar bushings ($22)
-TRD Strut Tower Bar ($60 used from another scion owner parting out)
I would recommend the rear sway bar and energy suspension bushing upgrades for immediate handling improvements. Then lowering springs/Shocks/struts.
Old Aug 19, 2011 | 08:16 PM
JIMXB's Avatar
GT Spec 4 point front chassis bar + 2 point mid chassis bar will also improve handling. I was lucky and won these items at a Scion Vip 2005 event.
Old Aug 20, 2011 | 12:19 AM
I should have mentioned in my op, that the box is already fitted with KYB Echo struts up front, TRD struts out back, and DF210's all the way around. Also just recently did the front end link bushings, so we can knock those off the to do list.
Right now I don't have the funds for wheels/tires, and/or coilovers, but they are on the list. Hence why I am looking for a simple, and somewhat inexpensive suspension upgrade such as the rear sway bar, or "H" brace, and since they are remotely close in price I'm having a dilemma deciding which way to go. Thanks for the input so far.
Old Aug 20, 2011 | 01:30 AM
Roller_Toaster's Avatar
If hotchkis makes a full spring/swaybar kit for the xb1 like the do for the xb2, I HIGHLY reccomend it. Along with a strut tower brace, it completely changed the cars handling characteristics in a good way .
Old Sep 1, 2011 | 03:07 PM
jcXB's Avatar
The hotchkis kit is nice for the gen1 if you can install the front sway bar. You will need to drop the engine compartment in order to do so. The alternative to that is the Energy Suspension bushings.
fur_pig
Mar 20, 2020 04:28 PM
debris
Mar 13, 2015 08:15 AM
RichBinAZ
Dec 21, 2014 12:05 PM
rancur3p1c
Dec 19, 2014 04:30 PM
XB_2
Nov 23, 2014 02:48 PM
