just finished installing my Forjworks air ride
Old Aug 28, 2011 | 11:03 PM
jungle_327's Avatar
Default just finished installing my Forjworks air ride
after many hours in my garage I have finally finished bagging my Xb. Here are a few pics of the install.
Let me know what you guys think. I plan on getting some lower profile tires.. maybe a little stretch so I can drop my front a little lower . Any recommendations on tire sizes for an 18x8 +40 rim would be appreciated.
Old Aug 28, 2011 | 11:10 PM
SamCarroll's Avatar
frick! thats perfect!
Old Aug 28, 2011 | 11:47 PM
flyingemu05's Avatar
im jelly. hopefully i'll have my car on bags soon.
Old Aug 29, 2011 | 12:19 AM
manley81bass's Avatar
sex
Old Aug 29, 2011 | 12:20 AM
CIONIDE's Avatar
What size tires are you running right now? I would think 215/40 or 205/45 would get you where you want to be.
Old Aug 29, 2011 | 01:32 AM
jungle_327's Avatar
im running a 225/45/18 at the moment. They were the only tires offered on a wheel and tire package that was too good of a price to pass up. Right now my fenderwells are sitting on my tires and I still have more room to drop in the front. I want something that will allow me to drive at a low ride height and that will allow me to drop my front more.
Old Aug 29, 2011 | 01:36 AM
jungle_327's Avatar
Oh yea i have 18x8 rims. And thanks for the comments guys
Old Aug 29, 2011 | 01:43 AM
YELOSUB's Avatar
Wagonistas
If your running 18x8, I would suggest running a 215/40/18 for a little stretch or 205/40/18 for a little more stretch...
Old Aug 29, 2011 | 04:46 AM
CIONIDE's Avatar
As you already know, 225/45-18 is way too big for your air ride drop. Those tires have a 26" outside diameter, which is over 1" larger than OEM. 215/40 are about 24-3/4" which will allow for 5/8" more drop than your current tires, and the 215 width will give almost 1/4" more clearance from the inside edge of the fenders. If you don't think that's enough clearance for the stance you're trying to accomplish, then 205/40 is the smallest tire solution I would consider. You could always drive with a tad more air on the 215/40's if you need to, then air it out when you park to show it off.
Old Aug 29, 2011 | 04:59 AM
masterbB's Avatar
looks nice
Old Aug 30, 2011 | 12:51 AM
Jay Blaze's Avatar
looks good!! how long did the install take?
Old Aug 30, 2011 | 01:48 AM
jungle_327's Avatar
Took me a three day weekend to get it up and running.... and I ended up stripping one of my sway bar link allen bolts... So I installed a new one the following weekend along with tucking wires and checking connections.. The overall install went pretty smooth tho
Old Aug 30, 2011 | 02:58 AM
Jay Blaze's Avatar
hmmm not to bad, especially if you worked on it alone!! great job bro!
Old Aug 30, 2011 | 03:04 PM
Ricersux's Avatar
I run a 225 width on 20" wheel and I can lay it out as far as it will go. I had to use as much neg camber available but it tucks!
Old Aug 30, 2011 | 05:26 PM
jungle_327's Avatar
How did you go about adjusting the camber?
Old Aug 30, 2011 | 05:31 PM
Ricersux's Avatar
The top bolt on the lower bracket of the strut is slotted to allow for some camber adjustment...its hard for me to tell in the pics if Marshall's struts are slotted or not. Might need some upper pillow mounts if you need tons of camber. A die grinder will help open the slot if you need a lil more down low.
hampton1100
May 28, 2015 07:32 AM
carid
Jan 22, 2015 12:49 PM
hotroddelux
Dec 3, 2014 11:33 PM
ScionVan
11
Dec 2, 2003 09:37 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
