Towing a Scion xA with a tow dolly behind a U-Haul?
I have a 2004 Scion xA that i would like to tow behind a U-Haul truck with a tow dolly (http://www.uhaul.com/Reservations/Eq....aspx?model=TD). Anyone know if this is ok? U-Haul says so, but just want to make sure (ie, no problems with transmission?) thanks
I am actually a General Manager at a Uhaul Center in Wisconsin. What size truck are you getting? If you get a DC or larger, it will pull smoother and be more comfortable. Also your Scion XA will work out perfect on a Tow Dolly. If its lowered just take extra precautions when loading. Just make sure all straps are on tight and you use both chains.
You should look into an Auto Transport, depending upon where your moving it may only be a small difference in price. It will give you much less hassle and worries as the whole care will be up on a trailer.
carid
Dec 4, 2014 09:35 AM
foxSCION
13
Dec 3, 2003 05:40 AM
