2011-____ [ANT20]
HELP!
Old May 19, 2012 | 09:58 AM
johndeo11's Avatar
Exclamation HELP!
so i was adjusting the ksport coils on rear. first i did the right side, it was successful. the came the left, while gonna install back the spring, i found this on the control arm - (photo)
i couldn't figure out where it came from. so as i finish installing back everything, i measured the height from fender to floor and it was the same left and right side. i went out to test drive, it was ok. when i came back, left side is lowered than right.
Old May 19, 2012 | 02:08 PM
speterson82's Avatar
I haven't looked on the car, but that looks to be a control arm bushing. Did you check or compare the left and right control arms to see if one is missing a bushing? Just a guess.
Old May 19, 2012 | 02:15 PM
CementTC's Avatar
Yea Def looks like a bushing
Old May 19, 2012 | 02:28 PM
Aztcrs801's Avatar
looks like the top sway bar bushing that sits on the rlca
Old May 19, 2012 | 03:29 PM
KidJustin's Avatar
DaYUUM/Scion Evolution
Old May 19, 2012 | 04:20 PM
devanb3's Avatar
^this i just installed my eibach sportlines and had to remove them you may want to get that back on before something gets messed up
Old May 19, 2012 | 05:29 PM
johndeo11's Avatar
^justin. nope. i checked it...
ima check it again right now...
thanks guys...
Old May 19, 2012 | 05:55 PM
devanb3's Avatar
It may be the piece on the other side of the control arm
Old May 19, 2012 | 08:28 PM
johndeo11's Avatar
^you're right... it's on the other side of the bushing that KJ showed it...
