tc lags in power problem
Old Sep 3, 2012 | 10:36 PM
rican_lunatic's Avatar
Default tc lags in power problem
so sadly to say my tc motor blew up. nd i put in another motor. i had two check engine codes pop up nd it was the cam position sensor nd a cel code got that fixed so my check engine light is off here is my main issue. I drove it for the first time nd 1st gear was fine nd when i shift it to 2nd gear it lags major power. i even tried to have the gas peddle all the way to the floor nd nothing. its super slow. i got new spark plugs nd coils so that cant be the issue. could it possibly be theres not enough gas going threw the injectors? so right now im pretty freakin clueless.
Old Sep 4, 2012 | 11:36 AM
Bump
Old Sep 4, 2012 | 02:40 PM
stocksciontc's Avatar
Just throwing this out there...
Is the TPS fully functional?
Old Sep 5, 2012 | 12:04 AM
I believe so but I herd there a possibility that there is a way to restart the tps idk if that's even possible
Old Sep 5, 2012 | 07:00 PM
Any ideas here or is everyone clueless?
Old Sep 6, 2012 | 11:42 AM
Bump
Old Sep 6, 2012 | 06:21 PM
BadDudeTC3's Avatar
Have you tried disconnecting the battery for 20 minutes so that the ECU can reset and relearn the fuel trim values again? You went from turbo to N/A so maybe the ECU has the values from fighting with the FIC and needs to be reset....
Old Sep 6, 2012 | 06:41 PM
BadDudeTC3's Avatar
PM me when you have a chance cause we have a meet tomorrow night and we can help you troublshoot the issue. A couple guys in the group are certified mechanics.
Old Sep 10, 2012 | 05:34 PM
R3define's Avatar
I was throwing a cam position sensor code and ended up replacing the vvt-i motor. Fixed the problem.
Dmmcclair
Aug 13, 2015 07:14 PM
JonathonK
Mar 9, 2015 09:49 PM
missing_image
Feb 7, 2015 07:18 PM
EvalEvan66
Jan 27, 2015 02:26 AM
andergtr
27
Jan 8, 2004 05:55 AM
