Heavy Duty Compressor question
Old Mar 12, 2013 | 04:07 PM
Penty's Avatar
Default Heavy Duty Compressor question
Hi guys
I would like to purchase the following item -
Amazon Amazon
but i am concerned about blowing fuses. The item description states that the power port must have a 15 AMPERE rating. My 2012 xD shows an outlet rating of 12 VOLTS/120 WATTS.
I know there is no way to convert amps and watts. I am guessing the answer lies in what fuse protects the outlet? If so, does anyone know what size that fuse is? Or any other answer??
Thanks in advance
Old Mar 12, 2013 | 04:38 PM
awisher's Avatar
That is 10 amps, no? You would need about 168-170 watts at 14amp. Additionally, if it is a compressor the motor probably has a peak start-up amp that is higher. Usually you add 50%. I doubt the wiring is capable of that level of amperage. It would be super easy just to run a larger wire directly from your battery to a dedicated outlet.
Something like this
Old Mar 12, 2013 | 04:39 PM
Lil_Deuce_tCoupe's Avatar
Check your owner's manual, or the fuse box. Each circuit is identified (horn, wipers, aux, etc), and the proper fuse (15 AMP, 20 AMP, etc.) for each circuit is shown as well.
You should be able to find the fuse / circuit rating for that power port there.
Old Apr 9, 2013 | 11:58 PM
morrisdl's Avatar
Find one with battery terminal clips. I have one very similar spec except clips for my off road vehicle.
gp1817
Mar 18, 2015 10:26 AM
Scionxa180
Mar 13, 2015 04:39 AM
carid
Jan 30, 2015 02:23 PM
xBassist
9
Jan 21, 2004 07:34 PM
