Randode cold cathode mounting (tC)
Old May 5, 2005 | 12:05 AM
Otsego_Undead's Avatar
Default Randode cold cathode mounting (tC)
I've everything all set up, and my front cathodes are mounted. my only problem is i have no idea where to mount the power inverters and cathodes under the seat. there isnt much clearance and I cant seem to find anything decent to zip tie it to. How has anyone else done it?
Also, Did you pull the wires UNDER the seat tracks next to the center console? ATM my inverters and cathodes are just sittin on the floor
Help!
Old May 5, 2005 | 06:01 PM
wilder's Avatar
It is kind of a pain, but you just have to find a couple of spots on the metal underframe of the seat to zip it to. If I remember right I had to do mine a little crooked to make it work. Just find a good spot for the inverters and zip them up.
I've had no problems with mine up to this point. As for the wires, again, if I remember correctly, you pull them under the tracks and up through the hole in the carpet with the other seat wiring.
Basically just do what you have to do to make it work and it should all turn out ok, if that makes sense. Don't worry about it too much.
Old May 5, 2005 | 06:55 PM
hejustlaughs's Avatar
The kit could be a little more easy on the length of wiring. Another feet of wiring would've made things a lot easier.
Old May 6, 2005 | 06:16 AM
yeah this is what i figgured. its quite a pain. this is a time where i had a pet midget. he could crawl under there and do it!
randode
44
Jun 29, 2004 04:19 PM
Opr8r
25
Jan 13, 2004 07:42 PM
randode
Nov 20, 2003 05:46 PM
Besk_one
Nov 17, 2003 09:28 PM
BlueBox
9
Sep 25, 2003 04:36 PM
