Importing a Vitz RS Engine?
Old 05-05-2005, 11:56 PM
fredrick_brown's Avatar
Default Importing a Vitz RS Engine?
Where can we get Vitz RS Engines or why can't we get them?
fredrick_brown is offline
Old 05-06-2005, 12:21 AM
TheScionicMan's Avatar
My guess on the WHY would be Federal Emissions... If it's not on the approved list and isn't made for the USDM, it probably doesn't even matter if they could pass the test or not most importers won't bother with it. They won't pass the inspection/approval. Is that car/engine available in Canada? You might need to take a run for the border...
TheScionicMan is offline
Old 05-06-2005, 12:50 AM
snuppy's Avatar
I'm not sure, but I thought the RS was a trim level and had the same 1.5L as the regular Echo/Vitz/Yaris/xB/xA...
snuppy is offline
Old 05-06-2005, 03:41 AM
the rs was the turbo 1.5 stright swap and i donot think sr20det or rb 20,25,26 came in cars in canada
Old 05-06-2005, 03:54 AM
KevinxB's Avatar
The new Vitz RS has the 1NZ-FE.
KevinxB is offline
Old 05-06-2005, 04:14 AM
sorry!rs turbo who has info
Old 05-06-2005, 04:37 AM
Keitaro's Avatar
Yeah, same engine but it comes with the TRD Turbo for the 1NZFE. The new Vitz RS don't have the Turbo option. One of the reason is that there never was a factory available turbo. The website below calls it "tuning plan."Also the new vitz uses Super CVT- or a 5-speed MT.
bB/ist/Vitz chassis code NCP13 tuning plan:
http://www.trdparts.jp/parts_trdturbo-plan.html
New Gen Vitz RS 1.5L (chassis code NCP91):
http://toyota.jp/vitz/grade/grade/index.html
Keitaro is offline
Old 05-06-2005, 05:34 AM
thanks dawg
Old 05-06-2005, 05:47 AM
what about the 1.3l..fe turbo engine ?any pic or dyno sheet ?how hard is it to swap .ill settle for that rumored to put down 200hp on stock bottom end true
Old 05-06-2005, 10:13 AM
it can take more than 200 on stock bottom end. but it's an ancient motor
hotbox05 is offline
Old 05-06-2005, 02:55 PM
ok ill keep it simple i just want info on the swap.who has done this,how is it working out ,was it hard to do.i do not care how the engine is if its a easy fit and cheap to do also makes good power its for me.
Old 05-10-2005, 02:06 PM
BeQuietAndDrive's Avatar
Dude, what don't you get?
There is no "Vitz RS Turbo Engine"
Sorry buddy, Gran Turismo 4 fooled you.
All it is, is a Vitz RS, with the 1.5 1ZNFE you already have, with an added TRD Turbo Kit. The kit is around $5,000 to boost 5 or 6 psi.
If the 1.3 motor you are talking about is the 4EFTE, then you should wait untill EL Prototypes releases their swap kit. No one so far is known to have swapped already.
BeQuietAndDrive is offline
Old 05-10-2005, 05:18 PM
uberscionofglendale's Avatar
the guy who had the el prototypes turbo swapped the 1.3L turbo i believe. don't quote me on that though.
uberscionofglendale is offline
Old 05-10-2005, 08:02 PM
yep he did and el did the 4efte swap also.
hotbox05 is offline
Old 05-19-2005, 04:25 PM
Admin Emeritus
Cockpit_XB's Avatar
You could probably find someone to import it but its gonna cost money to do it, if they can import sr20's or rb motors why not the vitz motor.
Cockpit_XB is offline
Old 06-05-2005, 07:38 PM
fireballfish's Avatar
the question is not if you can get a jdm vitz rs motor, the real question is why. the motor the xa/xb comes with is the highest output motor available in the bb/ist/vitz. the addition of a trd turbo kit is what gives the additional power to the vitz turbo.... it's not a different motor, just a dealer installed option....
fireballfish is offline
Old 06-06-2005, 10:21 PM
xAScionicle's Avatar
Please....
it is not our call to decide what someone is to do with their car.
We, should only voice "our opinions".
Many great cars have been built by going against popular ideas.
Anyway... for JDM spec engines an stuff, check out this
www.jdmtheory.com
xAScionicle is offline
Old 06-07-2005, 03:07 PM
Originally Posted by xAScionicle
Please....
www.jdmtheory.com
that's great and all if you're talking about a honda, but with our cars, we got the best motor available, period. the specs on the jdm 1NZFE are identical to ours.
Old 06-07-2005, 04:30 PM
That's very true.
My guess is, like most of us, we are grabbing at anything that may lead to
a decent power increase.
So far, I have not found the answer that I'm looking for as well...
Blitz - too much $$ for to little gain.
Turbo - damn cali smog laws.
engine swap - possibly, for the right combo and fit.
The Vitz/Yaris/Echo hatch, should be here in the states next year.
Overseas it has either the 1.0l. , 1.3l., or the 1.5l like ours.
I'm not sure, but I think the 1.3 can be had as all wheel drive and/or turbo.
But yeah, I would stick with the original 1.5.
k1114
03-06-2015 03:43 PM
kdanie
47
02-07-2006 05:46 AM
Risen_Son_Racing
05-06-2005 02:31 PM
dinkjs
35
01-13-2004 11:55 PM
TheRedBox
11
12-14-2003 07:24 AM
Quick Reply: Importing a Vitz RS Engine?
