Lubed up my moons
Old May 13, 2005 | 12:16 PM
pileofmonkeycrap's Avatar
Default Lubed up my moons
I rotated the tires yesterday and since I had the moons off, I lubed them with white lithium grease. Just sprayed the prongs on the inside lightly. No more creaking or pinging sounds coming from them now. I'll see how long the lube lasts, but should last longer than WD40.
Old May 20, 2005 | 04:54 AM
xBHAWK's Avatar
Default Moons sound (Racing Disks)
I have the Disks. They do squeek. This is a case where the cure is worse than the desease. I washed and waxed the stock wheels so that brake dust and dirt will slide right off. And I love the look of the shine on the stock wheels as seen through the spokes of my 9-spoke stock hubcaps. I am not yet willing to lube the wheel just to stop the pinging noise when the Racing Disks are installed. Also I wonder if white lithium grease might help them fall off and go flying like a frisby. Do you swap hubcaps or is the Disk the only one you run with? When dirt, crud and brake dust start to accumulate on your wheels, the balance of the tire/wheel assembly is affected.
Old May 20, 2005 | 10:30 AM
TheIcon's Avatar
Nothing like lubing the moons. Rubbing that slick white stuff all over them.
Old May 20, 2005 | 04:48 PM
I only run with the moons. I've driven over 500 miles and they're still on the rims. I just lightly sprayed the prongs...didn't soak them or anything.
Old May 20, 2005 | 05:28 PM
SciFly's Avatar
which brand? which model? Bought from whom?
Old May 20, 2005 | 05:55 PM
teyem9's Avatar
All I can say is WHAT!!!!
Old May 20, 2005 | 06:04 PM
Bought them from Moon Eyes.
Old May 20, 2005 | 07:06 PM
bB2NER's Avatar
Music City Scions
Default Re: Lubed up my moons
When they heat up all that lube will melt and coat your tires and the inside of your wheelwells with lube covered with road dirt. The sound may stay away never tried to "lube the wheel" Just lived with the noise. Good luck!
Old May 20, 2005 | 10:30 PM
Old_Punk's Avatar
Just curbed one of my Moons last night. Scratched the hell out of it. In that instant before it happened, a little voice in my head was screaming, "Dude! Don't parallel park! The curb! The curb!" But the Homer part of me, who was doing the driving, was thinking, "Huh? What?"
Time to order a spare or two.
Old May 20, 2005 | 10:49 PM
LaVa~NyC's Avatar
i have only lubed them once ,when i put the on the car..i used wd-40 no problems yet...although i did lose one then i found it like 300 feet away..i was driving then i hit a deep pothole on one of my deliveries,i came back to work and i noticed it...i had to backtrack then i got out of my car then i found it like 300 ft in the woods.....Mooons must of flew off lol
Old May 21, 2005 | 01:18 AM
bB2NER's Avatar
Music City Scions
Have you guys thought about getting the ones that mount with 3 screws? Might save alot of headaches
Old May 21, 2005 | 01:32 AM
Old_Punk's Avatar
Well, since I'm not set up to macine three perfectly placed holes, I don't want to risk mounting the disks off center, causing balance/vibration problems.
OB936's Avatar
since you wouldnt hear any noise with the window fully closed.....I will just drive it and leave the moons alone.............
curb rush???...nah no worry.....just wash and wax it then it will be fine.....not prefect but acceptable...IMO
Old May 21, 2005 | 04:27 AM
bB2NER's Avatar
Music City Scions
Ummmm, they come with directions and the weight of the screws will hardly make the wheel out of balance.
Old May 30, 2005 | 12:57 AM
kingsting's Avatar
I wrapped the prongs of my Moons with masking tape. Most of the ticking went away afterwards.
Old May 31, 2005 | 02:57 AM
Sciond's Avatar
and maybe some curb feelers.............
Old May 31, 2005 | 03:05 PM
The pinging noise couldn't be heard inside with the windows closed. But, I work on an Army base and have to drive through security checkpoints several times a day. It's those times when I have to stop, unroll the window and show my ID, that I hear the pinging. It was just a little annoying, so I decided to fix it.
The Lithium Grease is made for metal on metal contact and won't wash away like WD-40 could with water contact.
Old Jun 1, 2005 | 09:25 PM
xBino's Avatar
Old Jun 5, 2005 | 02:37 AM
jct's Avatar
jct
pssst, get your mind out of the gutters
Tak16
Jul 7, 2015 05:45 PM
pier0723
Scion tC 1G ICE & Interior
Dec 3, 2014 03:38 PM
SciFly
26
Sep 28, 2005 03:07 AM
Old_Punk
9
Nov 29, 2004 12:58 PM
XBman
56
Apr 3, 2004 10:07 PM
