Removing Wind Deflector?
Old May 17, 2005 | 04:32 PM
ack154's Avatar
Default Removing Wind Deflector?
So I want to make sure to get a couple decals on straight and figured that if it's not too difficult, I would just remove the deflector to do it while it's off the car. Anyone know how difficult it is? I didn't see anything in a search, so I was hoping someone has tried it.
Keep in mind, I'm mechanically inclined enough to do most things, so a simple "oh just take out these few screws and it'll come off" or something will be fine. I just haven't taken a good look at it yet to know.
Thanks!
Old May 17, 2005 | 07:46 PM
Greg2385's Avatar
I was thinking about doing the same thing. I dont really like the way it looks; however it does keep alot of wind from entering your cargo at higher speeds.
Old May 17, 2005 | 08:04 PM
ack154's Avatar
Well I don't want to remove it permanently... just remove it to put a decal or two on it and put it back. It's tough to reach to it and still keep things level and centered.
Old May 17, 2005 | 09:59 PM
garfull's Avatar
wow that seems like more work than standing through the sunroof and putting the sticker on upsidedown. if you could tape the deflector down the surface should be quite flat. keep us updated.
Old May 17, 2005 | 10:01 PM
hahaitzskippy's Avatar
removing the wind deflector will cause more air drag.
i say leave it on
Old May 17, 2005 | 10:05 PM
Kaeon's Avatar
i say leave it on
Your joking right or did you not read the post?,
Im pretty sure the glass is glued onto the slider.
Old May 17, 2005 | 10:14 PM
ack154's Avatar
I'm thinking about that too... I just dont want to get anything on my seats...
I took a quick look at the contraption. Looks like there are 4 hex screws (two on each side) holding down the deflector from underneath. Then there are little C clips connecting to deflector to the spring arms. Hmm...
Old May 17, 2005 | 10:15 PM
ack154's Avatar
i say leave it on
RTFP... not just the title.
Old May 18, 2005 | 12:55 PM
Kaeon's Avatar
RTFP Read The First Post I like that one!
Old May 18, 2005 | 01:13 PM
ack154's Avatar
Heh... well, "first" wasn't actually the word I was thinking of, but I guess that works too...
Old May 18, 2005 | 02:32 PM
LucidBD's Avatar
you do not need to take it off to get a vinyl straight. i did mine just fine...had help from 1 other guy but you just have to take measurement and mark with a dry erase marker that you can see on the deflector.
hint: lay it down before pulling the adheasive back in off. get it marked out and where you need it. then take some masking tape and tape the top portion to the deflector so that you can fold it back and it will still be in postition.
if you dont undetstand. i can do pics to make it easy for you.
here is mine~~~~~> http://i3.photobucket.com/albums/y58...D/DSC01454.jpg
keep in mind the deflector is convex shape like this ( so you will need to make small cuts on the bottom portion of the layout so it fits the curve
Old May 19, 2005 | 02:27 PM
TheBigGuyRy's Avatar
haha I like how we were on the same track with that one. I've come to automatically assume what F means in any internet acronym.
Kaeon, you've got an innocent and pure mind.
Old May 19, 2005 | 04:02 PM
Kaeon's Avatar
Heh, I knew what he ment lol
yhwhdesign
Jun 11, 2021 03:34 PM
laforze
12
Feb 16, 2016 12:50 AM
jnesselroad
Sep 15, 2015 06:57 AM
StxArOne
Scion xA Aero & Exterior
Aug 21, 2015 06:44 PM
excessads
Jul 13, 2015 11:41 AM
