WHAT NEXT?
Old Jun 22, 2005 | 09:29 PM
grandeville's Avatar
Default WHAT NEXT?
I just got my intake installed and my cat-back installed. What do you think is the next most importent thing i should do to get more speed out of my tc?
Old Jun 22, 2005 | 09:31 PM
CELL's Avatar
Wait for a good header
Old Jun 22, 2005 | 09:34 PM
Default Dealer!
I brought in prices from scionpartspeople.com to my dealer and they matched the prices. So just do your homework and most places will want your business.
Old Jun 22, 2005 | 09:36 PM
Is that the best bang for my buck? Do you think TRD will make one for the tc?
Old Jun 22, 2005 | 09:40 PM
toastbox's Avatar
how much money do you want to spend?
I'd recommend either a header, a better flowing s-pipe, or a port/polished head.
Old Jun 22, 2005 | 09:42 PM
CELL's Avatar
port/polished is pretty expensive huh?
How much gains do you see out of that? 10-15?
Old Jun 22, 2005 | 09:50 PM
I wanna gain as much hp as i can with out voiding the warranty. Also i dont wanna brack the bank. lol
very hard to do.
Old Jun 22, 2005 | 09:51 PM
toastbox's Avatar
P/P is defnitely expensive. By itself, you probably won't see much gains from it. But with an intake, header, and a bigger TB, you would see more gain, easily as much as 25% more flow in the head. Horsepower wise, I would *guess* maybe 10-20, given the above statements about I/H/TB.
Old Jun 22, 2005 | 09:55 PM
What about my warranty?
Old Jun 22, 2005 | 09:56 PM
toastbox's Avatar
very hard to do.
Indeed!
The biggest misconception about gaining HP is that significant numbers can be generated cheap and easy.
That's just not the case.
Your best bet is a header, a S-pipe, and/or a TB. you wont see a tremendous amount, maybe 10-15 between them.
A P/P head will *definitely* show HP gains, but you are looking at an additional $500 easily, above what you spent on the i/h/e components.
Old Jun 22, 2005 | 10:02 PM
Will scion be making a header that wont void my warranty? Also what is a s-pipe or a tb and will that void my warranty? If so what should i do? O' and thanks for the info people. Thats why i love sion. People who own them care about cars.
Also i have been getting lots of ____ about installing a aftermarket alarm. The knee air bags are not cool to work around. So they say..
Old Jun 22, 2005 | 10:04 PM
toastbox's Avatar
well, thats a tough one to answer...
the dealer isn't going to just blanket void your warranty because you have X part on your car. So let's say that you have some problem, you blow the motor, and it needs a rebuild.
The mechanic may or may not recognize the port/polish job on the head, so you might be okay. If the dealer does recognize it, it's 50-50. If the dealer can *prove* (not say or claim, he has to prove it) that port-polish job somehow caused excessive wear, then you wouldn't be covered.
More importantly though, and a far worse situation I think, would be if the delaer rebuilt your engine, but used a new head, rather than rebuilding yours! Underthose circumstances, you would need to get the p/p job all over again.
Old Jun 22, 2005 | 10:11 PM
toastbox's Avatar
Also i have been getting lots of poopie about installing a aftermarket alarm. The knee air bags are not cool to work around. So they say..
A header isnt going to void your warranty....
read about the Magnusen/Moss act under the technical faq's.
the brief summary is:
A dealer must *prove* that either the aftermarket part, or the faluty installation of said part, caused the damage *in question*, for the warranty to be voided under those circumstance.
For example, you buy a turbo, slap it on, and and you blow the head off your tc, because you were using too much boost. warrnty voided on the engine rebuild
you buy a header, and have it installed correctly. after 30 days, the head gasket fails and antifreeze mixes in your oil, and the bearings get coroaded. Warranty intact, unless the dealer can prove the installation somehow caused the head gasket to fail (very unlikely).
You install a s-pipe, the ECU goes beserk. Warranty intact.
Hope this helps
Old Jun 22, 2005 | 10:18 PM
So what do you think a good header is? Or a good s-pipe? Should i have the dealer install them? So is this my best next move? Or port-polish? where do i get it port-polished? How much should i expect to pay?
O and you know alot or i know nothing, but thanks either way
Old Jun 22, 2005 | 10:22 PM
Mr_Meaty's Avatar
Have you done any suspension upgrades yet? Sways? Springs? Struts? Grippier rubber?
I think the best upgrade you can do it sticky tires, cause it helps with handling and launches, as well as controlling your power.
Old Jun 22, 2005 | 10:24 PM
Sways? Springs? Struts? Grippier rubber? No
Do you think i should do that first? if so what? And by who? Also i know i always ask but is that coverd by warranty?
Old Jun 22, 2005 | 10:28 PM
toastbox's Avatar
Alphawerks is probably the best header out there right now.
Megan racing is currently re doing theirs, because they've had problems with the precats that are included in them. DC Sports have a lot of complaints about them
Weapon-R is coming out with a new header in the next couple of months, but rumor has it that it will be expensive.
A good s-pipe. ZPI (vendor on this site) makes one, draxas makes one, and James at creative compacts is making one.
Either the header or the S-pipe are probably your best next move.
P/P heads....you'd have to check out the shops near you. Or you could check on the board here, maybe under sponsored sales, or parts dealers. I *know* there are at least 2-3 places on here that offer that. It's going to be expensive though, like I said, expect to pay upwards of $500 for a p/p job.
Thanks for the compliments...but just remember, we all start someplace. Someday you could be giving someone the same knowledge I shared with you I learned what I know, the same way you are learning: asking , lol. One thing to be aware of though is to make sure you do a lot of research before you do anything, that way, you're covered in case someone *thought* they knew what they were talking about, but really didn't.
Old Jun 22, 2005 | 10:34 PM
Thank you. do you think though trd will come out with a header or not?
Old Jun 22, 2005 | 10:50 PM
toastbox's Avatar
I doubt it. Most TRD parts aren't even made my Toyota anymore, they're made by rebadged manufacturers: TRD springs = eibach. TRD supercharger = vortec. TRD 19 wheels for tc = Racing Hart
Old Jun 23, 2005 | 05:04 AM
Joe_Dezod's Avatar
Buy a header. Then tune the fuel and ignition maps (probably use an emanage). Clutch and flywheel from there and you'll have a pretty fun car.
