Echo engine capable of 145hp apparently
Old Mar 12, 2004 | 12:18 AM
Rayman's Avatar
Default Echo engine capable of 145hp apparently
I would like to know what was done to the engine. Article is not really clear in regards to that.
http://www.caranddriver.com/article....rticle_id=7902
Copied this off Car and Driver website:
And the surprising thing is the Prius handles superbly on the track. Don't expect the batteries and the electric motor to last more than one lap, though. With the accelerator floored constantly, the battery soon runs out of puff, leaving the car to run on its 1.5-liter four-cylinder engine. The power unit has incidentally been changed from an Atkinson unit with specially tuned valve timing and class-leading fuel efficiency to a less earth friendly but more conventional 1.5-liter engine, straight from the company's Echo small car, making 145 hp. On the track, the race version has 10-percent-poorer fuel consumption than the stock model. "This engine switch was necessary to achieve the results we wanted from the car. Otherwise," says chief engineer Masao Inoue, "we have done little else under the hood." The batteries are the same, and the THS II hybrid system is identical. Toyota considered upgrading the batteries and hybrid system to increase power output, but that would have meant totally recalibrating the THS II unit and battery pack, and the powers that be were not ready to do that just yet.
Old Mar 12, 2004 | 12:34 AM
snuppy's Avatar
not totally sure, but i think it's total hp of the gas and electric motor...
Old Mar 12, 2004 | 12:37 AM
Rayman's Avatar
Maybe that's what I'm missing. Maybe I have to read it again. LOL.
Old Mar 12, 2004 | 12:41 AM
Al-Truistic's Avatar
...and that's more than for us...!
That would be an awesome mod! Mores horsies AND better fuel efficiency? Oh my!
Al.Truistic
aB
jackmott's Avatar
I'm pretty confident a big cam and head porting and a slight redline bump to 7krpm and you could hit around 145hp no problem.
Old Mar 12, 2004 | 01:33 AM
ahurdl01's Avatar
i agree with jackmott, in naturally aspirated form if tuned right, you should be able to get at least 145 from the engine, though you may have to switch out some internals and lighten things up, cuasing a lose of torque, but hell of a lot of power
Old Mar 12, 2004 | 01:41 AM
MrSmiley's Avatar
The engine for the prius is the same size, but the block is machined alum. where ours and the echo is forged .... that's really the only dif. between the 1NZ-FE (echo)and the 1NZ-FXE (prius)...
Old Mar 12, 2004 | 02:14 AM
scionxb04's Avatar
im sure thats crank hp....and the motor is more then capable of 145 hp at the crank with what they were talking about...head/valve timing work etc....
http://home.earthlink.net/~graham1/M...Combustion.htm
and the blocks between the two motors are the exact same and aluminum...along with bore..stroke...displacement etc...
https://www.scionlife.com/forums/viewtopic.php?t=1685
rcflyer15
Dec 5, 2014 05:15 PM
ScionLife Editor
Nov 25, 2014 03:00 PM
danred7
Jan 28, 2004 05:23 AM
DarkMercury
Jan 28, 2004 04:20 AM
mikeluvsjo
12
Jan 9, 2004 06:47 PM
