track suspension setup
Old Mar 16, 2004 | 08:52 AM
scionxb04's Avatar
Default track suspension setup
im going to try kyb agx adjustable struts and not to sure on the springs yet....anyone out there know of good springs for a 2k civic si for track....im looking into either tein or suspension techniques for springs....but looking into other options....
Old Mar 16, 2004 | 07:17 PM
its_ikon's Avatar
if you are going for a track setup go for true adjustable coil-overs. if are set on springs and struts then look into tokico and go with the tein. st's are not bad, but tein is a nice spring.
Old Mar 16, 2004 | 07:42 PM
jackmott's Avatar
Default Re: track suspension setup
try asking a civic form first of all, theres lots of them.
secondly, if you are going to stick with KYB adjustable struts, then get some ground control coilovers. I know many of their honda applications are only like $250 and get you adjustable ride height, and they use eibach linear rate race springs.
most other aftermarket springs are a compromise progressive design.
Old Mar 17, 2004 | 12:35 AM
scionxb04's Avatar
it was posted in the off topic section....hmm o-well....thanks for the info....im probably gonna get a set of teins and a set of suspension techniques to try....the suspension techniques by far have the highest spring rate i can find so im gonna try them first....
if i like them....ill copy the setup to the scion.....the setup im taking off the civic is tokico illumina adjustables and eibach pro kit.....which had a nice ride....but is not stiff enough for track use.....
Old Mar 17, 2004 | 06:36 AM
jackmott's Avatar
tein can make any spring rate you want
so can most of the coilover companies
Old Mar 17, 2004 | 07:18 AM
hahajoey's Avatar
if u get shocks.. KONI YELLOWS hands down.
they cost over 5 bills...
teins start at 6-7 for a cheap price and about 8-9 retail.
spending anther 2-3 bills can get u teins, which will be better in track and u have dampening, and hieght adjustments.
but keep in mind koni yellows have like 3 perches u can rest the spring cup on so u do have a lil play in height.
Old Mar 17, 2004 | 01:49 PM
jackmott's Avatar
my konis have only 1 perch.
and on the rear, the springs don't perch on the shocks.
what koni yellows are you talking aboot?
Old Mar 17, 2004 | 02:28 PM
DjFrOsT's Avatar
i'd have to agree...tokico do have some nice struts...with tein would be a great set up...thats what i had on my civic...
Old Mar 17, 2004 | 03:53 PM
hahajoey's Avatar
tokico blue, alumina's and kyb agx and all that is good stuff for street.
KONI YELLOW is the best aftermarket shock on the market for track.
not the springs, but the shock itself has perches where u are able to rest the spring cup(the part the spring rests in on the shock).
ps: koni yellow's lifetime warranty is speaks for itself in quality.
please read these links:
http://www.honda-tech.com/zerothread?id=784144
http://www.honda-tech.com/zerothread?id=753401
05rs1
Dec 9, 2016 02:18 PM
Subaru86
Jul 31, 2015 04:33 AM
Subaru86
Jul 31, 2015 04:00 AM
tribe
Jul 25, 2015 05:21 PM
goatbelly
Jul 12, 2015 10:13 AM
