camber kit required on H&R springs??
Old Sep 14, 2005 | 02:25 AM
xtcx86's Avatar
Default camber kit required on H&R springs??
just wanted to know if any one on here has H&R springs for the tC and if they need a camber kit?? feedback would be appreciated.
Old Sep 14, 2005 | 04:56 AM
slammed's Avatar
i have tein coilovers which go far lower than the H&r springs and I dont need one. The tc's camber doesnt change to much. It would be benificial if your tracking your car.
You deff. want an alignment though.
Old Sep 14, 2005 | 07:07 AM
reagulator's Avatar
i have H&R no camber kit needed
Old Sep 14, 2005 | 01:19 PM
echelonphoto's Avatar
Hi,
Where did you get the H&R springs? They don';t even list them for this car
Old Sep 14, 2005 | 05:14 PM
reagulator's Avatar
I bought them here
Old Sep 14, 2005 | 10:14 PM
t0p_sh0tta's Avatar
Not to be a *****, but do you have actual proof of this?
I can't see how a drastic change in the height of a car will not drasticly affect the camber.
Old Sep 14, 2005 | 10:28 PM
reagulator's Avatar
i think what he was saying was that even thought the camber changed it isnt a big enough change to require a camber kit. The suspension is adjustable enough to fix it without a kit
Old Sep 15, 2005 | 03:17 AM
SciFly's Avatar
Not to be a tick but I do bite a bit to write to say, it does not hurt much to have a degree or so of negative camber in front. This would make an aid to cornering because the roll of the car uprights the cambered wheel on the outside to a more nearly vertical condtion. Cornering traction is markedly improved.
There is a penalty more or less to tire tread life, but even that can be mostly avoided by compensating with a bit of toe-out.
With front camber in particular you can see that straight line traction is trans-figured over to cornering traction and reduced understeer.
Old Oct 2, 2005 | 03:25 PM
sensay's Avatar
i have H&R Race springs and at first the camber was bad but with a simple alignment it was all good
Old Oct 3, 2005 | 07:54 PM
lo_bux_racer's Avatar
Not my experience. Negative camber is all good for drop the tC can make. Toe is not. A 2" drop got me 7/16" toe in at the back. Not good at all. Toe is easily corrected as is rear camber, but the front camber is more challenging to restore to stock numbers (which promote severe understeer anyway).
NonStopTuning
Jun 29, 2015 07:42 PM
STCxB
11
Jan 9, 2015 04:30 PM
kleecker
Jan 2, 2015 08:09 PM
Alvie
Dec 12, 2014 05:04 AM
k1114
Nov 30, 2014 01:40 AM
