Rough idle after header install.
Old Oct 6, 2005 | 05:23 PM
dslroxx's Avatar
Default Rough idle after header install.
I installed one of those generic eBay SS headers a week or so ago and I notice it idles rougher than it did before the install. I don't notice it so much when the car is in park or when I'm driving, but it is very apparent when I am in gear at a stop sign. I haven't had a check engine light yet for the header install or the short ram install, either. Would it make sense to reset the ECU anyway? Does anyone know wether this will fix the problem or what will?
TIA,
Mike
Old Oct 6, 2005 | 05:35 PM
TheScionicMan's Avatar
I'd try the reset. And on startup after resetting, let it idle for 10-15 minutes with occasional light revving. Gives the ECU a chance to make sense of what's there. That's where I'd start at least. Also, make sure your not getting an exhaust leak around the header and check to make sure the axleback portion of your exhaust is not touching the lip...
Old Oct 6, 2005 | 05:48 PM
Oni-Haya's Avatar
Originally Posted by TheScionicMan
4 8 15 16 23 42 - Execute
Now that is a true fan!
Old Oct 6, 2005 | 05:51 PM
VoLktc's Avatar
check the o2 sensor it may have been damaged in the install they are very fragile
Old Oct 6, 2005 | 11:24 PM
BrianxB's Avatar
a MAF could cause that as well. If youve had the the short ram on for a while and re oiled it, the oil the from filter can cause this. Clean it wih non chloronated cleaner.
Old Oct 7, 2005 | 03:45 PM
dslroxx's Avatar
Thanks for all the ideas, guys. I reset the ECU as per the tutorial and that took care of 90% of the problem.
Old Oct 16, 2005 | 03:20 AM
Safariworld's Avatar
Regarding problems with headers, I was told that to make a header most effective, the ECU would need to be enhanced with at least a piggyback. Can anyone confirm this? Cuz all this time I thought that plugging in a header was the same as plugging in an intake
RY_TC07
Jul 18, 2017 05:18 PM
the90am
Jun 19, 2015 08:04 PM
skruff
Jun 17, 2015 12:01 PM
Maarifa
Mar 13, 2015 04:07 AM
cid_mcdp
Jan 5, 2015 02:45 PM
