split rear hatch?
Old Oct 23, 2005 | 10:45 PM
andrewmachala's Avatar
Default split rear hatch?
Has any one thought of spliting the rear hatch in two so that the top glass lifts upward and the bottom folds down like a tail gate?
Old Oct 23, 2005 | 10:55 PM
cherryBox's Avatar
yes!
At the very minimum, I've thought it would be nice to have the glass lift. Do you have any ideas as to where to start?
Old Oct 23, 2005 | 11:00 PM
K_Dawg_ONE's Avatar
Ive thought about it too...like a Blazer!
Old Oct 23, 2005 | 11:06 PM
It was just a thought ,but i thinkit wouldn't be to impossible to try. My thought was to cut a stock door right below the glass and then reinforce the insides.
Old Oct 23, 2005 | 11:23 PM
RedneckwithanxB's Avatar
ive thought about it, and i have removed parts off my Chevy s-10 blazer...no lie...and used them to get an idea as to what i could do, im calling it not probabal at this moment, because i dont have another hatch to cut up yet
Old Oct 23, 2005 | 11:27 PM
So you think it wouldn't take much to make it happen? I think you just need the bottom hinges and some kind of latch assembly to got things going.
Old Oct 23, 2005 | 11:29 PM
stick_1NZ's Avatar
Do it...do it...do it.....This will be an interesting mod.
Old Oct 23, 2005 | 11:38 PM
George's Avatar
Let's see.
Remove hatch.
Cut hatch in half and reinforce it while keeping its shape.
Build door overlap flange between upper and lower half.
Build new hinges into the bottom of the hatch and body.
Build new limit straps for the lower half.
Build latches for the sides of the lower hatch.
Build operating lever for lower hatch.
Build a latch for the new bottom of the top hatch.
Build new seal and seal holder for joint between upper and lower halves.
Get everything aligned.
Disassemble and paint.
Reassemble and realign.
Simple, no?
Old Oct 23, 2005 | 11:43 PM
Hey some people see the glass half fulland then theres the other people. I think it's half done ,you got the door. Just adapt some already existing equipment to make it work.
Old Oct 24, 2005 | 12:13 AM
George's Avatar
Not saying you can't do it. It just won't be done in a half-hour like on Monster Garage. Making it work will take some time. Making it work well and seal properly will take even more time.
Old Oct 24, 2005 | 12:37 AM
hell i designed everything, did a photo shop, re designed, and still, im friggin clueless...i would love to do it, and even a way to get the door to open you could use the factory release, just move it to the top of the bottom panel...this way the top glass releases and goes up, the bottom swings down
but why do it on a vehicle that is this low, i could understand on a factory suspension box, but i have teins, big difference
Old Oct 24, 2005 | 12:42 AM
bBlover's Avatar
Sounds like a good mod. Do it Do it Do it!!
Old Oct 24, 2005 | 06:03 AM
Guamsilverbox671's Avatar
INteresting mod,
Japan has the opendeck Bb model. Wonder if it's possible to get the neccesary parts from japan, since it's OEM to make this modification possible
The rear bumper might need some modification too.
Old Oct 24, 2005 | 06:11 AM
BLKScion's Avatar
i think this has already been asked a few times..def a cool mod to try, my honda element has a slipt rear, its nice casue you can use it as extra seating, def be a cool look on the xB
Old Oct 24, 2005 | 06:13 AM
Tomas's Avatar
Admin Emeritus
On the OD, the entire chassis/body back of the "B" pillar is different. Just strengthening the lower chassis to handle the lower portion hinges is more than "simple."
(Monster Garage stuff doesn't have to last for 100,000 miles in real use...A lot of their stuff also just looks good from one angle, and that only until it breaks from normal use.)
Old Oct 24, 2005 | 01:56 PM
if someone comes across another rear hatch i would love to go in on this project with them...
Old Oct 24, 2005 | 03:14 PM
X_Box's Avatar
Scion Driven Girls
sounds kool....
Do it!
Old Oct 24, 2005 | 03:21 PM
khaye's Avatar
how 'bout just have the window go up and down just like a 4runner and get the hardware from a 4runner
Old Oct 24, 2005 | 03:54 PM
that would be awesome to do, but, if you ride around with the window down or out, all the exaust gasses come righth inside the car...
Old Oct 24, 2005 | 04:05 PM
Chillaxin206's Avatar
That would be nice to have, at the least just to get stuff out of the back without having to open up the whole door.
