CamCon with supercharged xB
Old Nov 3, 2005 | 04:54 PM
JoeDarkness's Avatar
Default CamCon with supercharged xB
Any people has had good results using Cam-Con combined with Supercharger/Turbo? on xB or xA?
Improved performance? More power? Etc?
Old Nov 3, 2005 | 07:35 PM
Simplyscion's Avatar
Team No Limitz
Mine didnt work for **** on my turbo xB. It would only work for a lil while until eventually the long term fuel trim would reject the settings and then not really know what to do when it sees boost.
Old Nov 4, 2005 | 02:11 AM
Uhhg
Do you think that Apexi SAFC II is better?
Old Nov 4, 2005 | 09:26 AM
Team No Limitz
nope...these piggybacks only seem to work well with N/A applications.
Old Nov 4, 2005 | 03:18 PM
Xbilly's Avatar
TurboXS Dtec fc has a boost option now i think, says it works well with closed loop systems.
Im trying to get a review from matchbox about his TurboXS set up, i haven't PMed him about it but he hasn't answered if the forums, I dont want to pester him but I'm curious as hell. I want to go with turboXS, but not if it deosn't work well.
Old Nov 6, 2005 | 12:54 PM
So, CAMCON is best than SAFC?
Old Nov 6, 2005 | 06:35 PM
UncivilizedRacer's Avatar
The Dtec unit works GREAT on my Turbo SRT-4. Not installed yet on my box since the thing is still on blocks having everything intalled. Will have info on it within like 2 months when everything is completed though!
Old Nov 6, 2005 | 08:08 PM
Xbilly's Avatar
Can't wait to hear about it, but I hope to have it set up in just a few weeks.
Old Nov 6, 2005 | 08:15 PM
Wraith's Avatar
The problem isnt in your piggy backs its your factory fuzzy logic ecu ... The only way to really make power is to do a complete ecu swap and then hook up the piggy ecu...
The factory ecu trys to achieve fuel and timing maps closest to the factory mapping. Once you guys tune on the dyno ... Shut down the car and let it cool and then re-dyno you'll see that you've lost most or if not all of the power you guys just gain the dyno before...
Old Nov 6, 2005 | 08:16 PM
Wraith's Avatar
can someone post their supercharged dyno's and in the end of the month we can compare it to a fuzzy logic vs echo non-fuzzy logic ecu ...
Old Nov 6, 2005 | 11:32 PM
Sciond's Avatar
matchbox has posted his do a search...also he scrapped the cam con
Old Nov 7, 2005 | 12:36 PM
Why he scrapped the cam con?
Old Nov 7, 2005 | 12:45 PM
dgHotLava's Avatar
go see the second post....
i also ditched mine. doesn't work for FI set ups.
would run fine for a day, then throw codes...
got fed up and stopped using it.
Old Nov 7, 2005 | 01:06 PM
My cam-con works fine, but I only use the suggested configuration settings posted in PE website. I dont see any difference in performance. Only difference is that i have now a digital tach jeje.
Old Nov 7, 2005 | 11:09 PM
Xbilly's Avatar
Do you use anything now, or just the mechanical (rail, pump, injectors)?
Old Nov 8, 2005 | 01:29 AM
I think if its good idea or not change the stock injectors...
Old Nov 8, 2005 | 01:30 AM
dgHotLava's Avatar
my car is really tuned well with the mechanical stuff.
pump, rail, injectors, regulator....
i've been going through different systems to find the best application.
nothing impresses me yet.
Old Nov 8, 2005 | 03:45 AM
Wraith's Avatar
Hey bro did you convert to a return type system on your fuel ???
Old Nov 8, 2005 | 01:42 PM
What type of regulator do you use?
Old Nov 8, 2005 | 02:10 PM
dgHotLava's Avatar
no. it is still a single line.
i've been tempted to go return style, but the folks i know who did it have had problems.
my set up has yet to lean out on me so i'm not in a rush to do it.
