manual tranny..reverse grind
Old Dec 23, 2005 | 07:00 PM
db_17_85's Avatar
Default manual tranny..reverse grind
Alright.... I was backing out of a friends driveway the other day. I was rolling back and tried to put into reverse (yes, I pushed in the clutch). It just grinds. So, I hit the brake, come to full stop..try again. Works fine. So, I've tried a few things... going forward..fully depress clutch...go through gears...only reverse grinds. Now, mind you..this is all with the clutch fully depressed. Even while in reverse..I'll stop, put it in reverse and go without problem. Press in the clutch, go to neutral, press clutch again and while trying to go into reverse, it grinds. This is a 2006 tC. Does reverse have no synchro? Is this a common thing, or does this need some attention?
Old Dec 23, 2005 | 07:08 PM
jmiller20874's Avatar
Reverse uses a straight cut gear and the car MUST be at a complete stop before it will allow you put it in gear. This is completely normal and by design. Nothing's wrong.
Old Dec 23, 2005 | 07:13 PM
db_17_85's Avatar
gracias
Old Dec 23, 2005 | 07:26 PM
gcxandy's Avatar
our Reverse gear isn't sync'd , sucks.. i found out the hard way to. trying to pop it to R rollin down my driveway lol.
Old Dec 23, 2005 | 08:19 PM
L_Ours_Polaire's Avatar
Default more information
Hi !
The grinding is because they are no syncro on reverse
(also why it is so hard to engage when moving)
The whining when you back up is because de gear are straight cut
(but only on manual trany)
Now
I have a question that one teacher I had asked us AND didn't have the answer (bastard)
Why are the reverse gear straight cut ?
Take care
Z-Bear
Old Dec 23, 2005 | 08:36 PM
aarontrini85's Avatar
http://auto.howstuffworks.com/question522.htm
love that site lol
Jess125drw
Sep 15, 2015 06:57 AM
TC_LOWLIFE
mikeytomas
Aug 6, 2015 08:54 PM
DryToast
Aug 4, 2015 02:59 PM
Mpwr
Jul 17, 2015 08:39 AM
