Oil block adapter
Old Apr 23, 2004 | 06:49 AM
Minsk99's Avatar
Default Oil block adapter
I am going to install an oil block adapter so I can hook up some gauge senders to it. I was wondering if I can remove the oil filter without draining the oil first?
Old Apr 23, 2004 | 02:23 PM
softrider's Avatar
lol
Old Apr 23, 2004 | 02:43 PM
Munch's Avatar
Default Re: Oil block adapter
No way I hope you were kidding by asking that question. You have to drain the oil first
Old Apr 23, 2004 | 02:54 PM
hotlanta's Avatar
N.G.S.O.
Tell you what, why not just turn the car upside down?
Old Apr 23, 2004 | 03:25 PM
sithscripter's Avatar
I've been thinking about installing the Greddy oil block adapter myself. Good luck on the project -- please post photos :D
Old Apr 23, 2004 | 04:19 PM
Minsk99's Avatar
Nope. Not kidding about this one. My buddy insisted that the oil would settle back into the oil pan over night and that only a little oil would leak out when I took out the filter. Anyway, I've only changed oil filters at the same time as changing the oil so I didn't know, but it sounded kinda weird. Thanks for the heads up.
Old Apr 23, 2004 | 04:30 PM
Theglen10's Avatar
Your friend may be right. Depending on where the oil filter is installed you may be able to change the oil filter without draining the oil pan. The oil pan is the lowest point in the oiling system and it may drain back into the pan. If you can do this on a Scoin you will only loose the oil in the filter. Having said this, I don't know where the oil filter is on my XA and may never find out as I let someon else do the oil changes at my age.
Old Apr 23, 2004 | 11:14 PM
Minsk99's Avatar
Guess what? I didn't have to "turn my car upside down" and was able to take out the oil filter without draining the oil. I let the car sit overnight and all of the oil went back down to the pan. Only a dribble was left. So if y'all are wondering if you can change the filter without changing the oil, the answer is yes. Just make sure that you let the car sit for a while so the oil can settle back.
Old Apr 26, 2004 | 08:55 PM
Distracted_Thinker's Avatar
Theglen10 I just got my xa and every one kept asking me where the oil filter was so I looked around and I belive I spoted it in the front portion of the engine way at the bottom dont really know how else to explain it. Also it looks real easy to change looks like all you would have to do is crawl in from the front a inch or two and you can reach it. hope this helps
k1114
43
Mar 1, 2023 03:08 AM
BlackKnight
Sep 15, 2015 06:42 AM
my06tc
Jun 25, 2015 12:18 AM
Munch
Mar 26, 2004 01:16 AM
