15x7x+40 rims with stock tires?
Old May 4, 2004 | 05:28 AM
NewCreature's Avatar
Default 15x7x+40 rims with stock tires?
I just picked up my Hot Lava xB today! Anyway, with the terrible roads here in East Texas, I decided to stick with 15s. In my browsing around on ebay I found the following...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2477049111
When I first saw them and put my snipe in on them, they were at $60 for the set. I could hardly pass them up at that price. As usual though, the price climbed at the end and the original buyer backed out, clearing the way for me to ****** them up at $55 each after shipping. Seems like a reasonable deal. What do you think? Anybody heard of Sacchi wheels? The seem to go for better than $100 each typically Also, will the 15x7x+40s cause me any problems with the stock tires or in the wheel wells? Will I need any spacers or anything?
NewCreature
<><[img][/img]
Old May 4, 2004 | 05:36 AM
JDMxB's Avatar
Congrats on winning that auction, I know how it is to sit and wait anxiously on Ebay--i've done it many a time.
The sticky about wheel fitments is the first post in the Tread and Butter forum
https://www.scionlife.com/forums/viewtopic.php?t=348
and regarding your particular fitment this is what we find--
15x7.0? . . . . . . 38 . . . . . . . . . . . . . 185/60-15 (Stock Tire)
So someone before has used a 15x7 et 38 with the stock tires and it worked just fine.
I'm assuming that +40 would work fine as well...I don't think you will need to run spacers of any sorts--but if you do find it ending up rubbing, a simple 3mm to 5mm spacer would work with no additional hardware needed to make the wheels fit.
Also there would be no problem using your stock tires.
Old May 4, 2004 | 08:09 AM
tinybigrig's Avatar
the offset will be fine, but on your tire they may be sunken in bc the rim is wider than the stock one
brent
Old May 4, 2004 | 07:08 PM
softrider's Avatar
Now that you have a wider rim, why not go for a wider tire? The wider tire would result in an improvement in both handling and comfort. Something like a 205/55/15 actually gives you a little bit more sidewall than the stock tires. A 215/50/15 would fit, but don't know about any potential rubbing problem. Also such a wide tire would probably be rather expensive (except for the cheap Kumho 711).
Old May 4, 2004 | 07:41 PM
frosty's Avatar
I have 15's cuz I like more tire as well, the roads suck up here in the north east so i know what your sayin
Old May 4, 2004 | 09:04 PM
Sid_xBicious's Avatar
brent
stretch, VIP style
Old May 5, 2004 | 04:37 AM
sithscripter's Avatar
That fitment might actually be a little bit close ... The sidewalls will "fill out" on the wider rim so you'll end up with a combination about 1/2" wider than stock. That puts the widest point fairly close to this one bolt head that sticks out of the rear suspension.
I run the stock tires on 15x7, +38 (???) rims myself. Everything fits OK but I'm tempted to put 5mm spacers in back.
blh72
Scion xD Wheel & Tire
Feb 2, 2015 12:36 AM
JPuehl
Scion tC 2G Wheel & Tire
Jan 22, 2015 02:44 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
BlueBox
18
Oct 1, 2003 12:58 AM
