are wheel spacers bad?
Old May 14, 2004 | 12:13 AM
nosSER's Avatar
Default are wheel spacers bad?
I have been searching the forums alot lately and plan getting an xb in june. I have read about wheel spacers and I was wondering if they negatively affect the car or handling. I thought I read a post that said it did but I'm not sure. It it better to get wheels that will fit perfectly or is it okay to put a 15mm spacer in the rear?
Old May 14, 2004 | 12:17 AM
mod7XB's Avatar
15mm why would you need that much. normal is 2-3-5 mm 15mm is deep you will loose alot of bolt threads
Old May 14, 2004 | 02:02 AM
stnley's Avatar
spacers are fine as long as you dont buy the cheapo's, stick with H&R. 15mm to 20mm is perfect for the rear since the difference in the front and rear wheels is 1 inch (25.4mm). you don't have to worry about the studs because you have to replace them with longer studs if you put anything bigger than 5mm spacers on the vehicle.
terrye
Jan 25, 2015 05:31 AM
CAtC12
Dec 23, 2014 04:44 PM
avus
14
Aug 6, 2004 09:27 PM
scionara
38
Feb 25, 2004 04:52 AM
Hardhitten
Nov 2, 2003 08:29 PM
