Can this be removed?
Old May 25, 2004 | 11:59 PM
Buebie's Avatar
MN Scions
Default Can this be removed?
Can the white piece on the floor be removed without strc/ other problems? I cant stand the foot rest thing on the left, my feet are huge and its annoying. (sz. 16)
BTW this isnt my car, I just needed a good example
Old May 26, 2004 | 12:52 AM
its_ikon's Avatar
i don't see why it couldn't be removed. unless it is protecting something beneath the foam.
Old May 26, 2004 | 03:08 AM
Max2k's Avatar
Carpets might not go down right.
Old May 26, 2004 | 03:56 AM
ncscion's Avatar
^^^ i seriously doubt this. the carpet in my scion is thin and flimsy as ____. almost like paper. i figure i will be needing to replace it within the first year.
Old May 26, 2004 | 04:00 AM
Da_BoX's Avatar
NcScion
I agree bro
Old May 26, 2004 | 04:11 AM
DenZinz's Avatar
the carpet is form fitting so if you remove the styrofoam it will feel like something is missing. it can also cause premature wear because its not sitting where it suppose to.. If toyota thought i didnt belong there, they wouldnt of put it there.
Old May 26, 2004 | 04:54 AM
TheScionicMan's Avatar
They put it there expecting people with human sized feet. Damn... 16s!!!
I kid I kid.
Like Sam said, unless there's something under it that is being protected, I don't see the big deal...
It's styrofoam, it can't be doing much other than hold the carpet colored paper up...
Old May 26, 2004 | 01:42 PM
breunor's Avatar
Wearing size 17s, I can empathize. With the upright seating position, this footrest is less necessary IMO. You could carve into the foam from the side to make sure nothing is under it, then cut it all out and patch the spot with additional carpet. And then make a better mud guard as well!
Old May 26, 2004 | 02:07 PM
tbblizzard's Avatar
I kid I kid.
aaaahaha
Old May 26, 2004 | 02:21 PM
theotherchrist's Avatar
If the carpet is fitted you can use a steam gun on it to lossen the adhesive and make it give up it's shape. We had to do the same thing in my dad's '69 mustange after he moved the seats back four inches.
Old May 26, 2004 | 04:45 PM
its_ikon's Avatar
I kid I kid.
another way to look at it is that if you have problems after removing it you can always put it back in.
Old May 26, 2004 | 05:24 PM
Buebie's Avatar
MN Scions
I appreciate the input, thanks for the replies.
The damn fallout, I knew I was in trouble when I walked through that glowing green field.
Old May 28, 2004 | 12:20 AM
MotoMan_YZ400's Avatar
yeah go ahead, you might save .1lbs after removing it, maybe it can compensate for the 300lbs of Dyno mat you put in there!
Old May 28, 2004 | 04:26 PM
did you take it off yet? were you able to ge the carpet down and form it to the floor? Where are the pics. :D
Old May 28, 2004 | 10:52 PM
Buebie's Avatar
MN Scions
Im in Minnesota, so we dont get the scions for another week or so. I just remember in the test drives, the left foot rest was irritating.
Old May 29, 2004 | 12:01 AM
Ok so your just gettin ready.
Old Jun 1, 2004 | 02:28 PM
Buebie's Avatar
MN Scions
Well, I was ready when I orderd it in March lolz.....but yea, I'm just ready to tear out the stock crap and start modding. I've got all my stuff ready like a pit crew waiting to change tires
Old Jun 1, 2004 | 05:45 PM
rolex87's Avatar
BTW, that's my car when we were installing dynamat. The foam piece seemed pretty loose, but carpet fitment will become an issue after a while, unless you trim the carpet to compensate for the hole or something..............
Mike R.
rolex87
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
steeze69
May 24, 2021 02:57 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
jbernard
Sep 3, 2015 12:03 AM
