Goldline Springs !!!
Old May 27, 2004 | 05:54 PM
MyBoX's Avatar
Default Goldline Springs !!!
Just want to say thanks to Bill (scionspecialistvegas) for great and FAST service, I had my springs in two days, got them installed yeterday, Ride quality is not bad at all compare to other lower car I have been driving, on freeway you can feel the road more but regular driving I can not feel anything. After drop I got about 1.5" all corners but this morning I have 2" in rear but not in fron, again best spring for the money, The only issue that I have (May be this the way it should be) When I pass over a bump or a hole no matter what speed or which tire, I hear this loud BLUMP (clicking) sound comming from the corners (suspensions), like the car is botteming out or something, does anyone have this issue ?? Thanks again Sean
Old May 27, 2004 | 05:58 PM
BlueBox's Avatar
Default Re: Goldline Springs !!!
Did you cut the bump stop in the front struts? cuz if u don't ... u 'll be bottoming out like u're experiencing.
here's the explanation and reason for trimming the bumpstop...
In order to maximize the performance and ride quality of your Gold-Line coil springs, it is necessary on certain applications to trim the factory bump stop as described below.
Bump stops can easily be trimmed with a small hacksaw. Simply find your application and measure accordingly for the amount to be trimmed. It is recommended that material be removed from the top section of the bump stop. Trimming the bump stop will provide additional suspension travel (lowering a vehicle reduces suspension travel). This will insure a more comfortable ride. Bump stops are typically found on the shock / strut shaft beneath the dust boot. Always re-install bump stops. Failure to do so will result in permanent shock and/or strut damage.
for Scion xB... recommended bump stop trim for the FRONT struts is 1" trim.
Old May 27, 2004 | 06:48 PM
MyBoX's Avatar
Thanks for the advice, yes I did, cut it 1 1/2" but may be I should let them settle for a week or so and then see what happen, but just again want to thanks Bill, he already snet me two messages to get the problem solve, now that's customer service !! Sean
Old May 29, 2004 | 03:59 AM
scionspecialistvegas's Avatar
Sean, anything else i can do let me know, wnat to keep you scionning for long time. Bill
Old Jun 21, 2004 | 02:23 PM
Lip's Avatar
Lip
Default thanks bill
thanks Bill. our 3 scion xB's now have Goldlines. very good spring...very good.
maybe i'll see you in Vegas in August
Old Jun 22, 2004 | 12:23 AM
MyBoX's Avatar
Bill is the Man, thanks again Sean
Old Jun 22, 2004 | 02:04 AM
Lip's Avatar
Lip
btw....here it is with them installed
Old Jun 22, 2004 | 08:19 AM
Thats sweet, right know we have guest from the PI, so we will be in cali for a few days, Lip I will get the info when we get back in town. Thanks again everyone for your business. Bill
prescottn
Feb 24, 2016 11:57 PM
Itgb
Sep 2, 2015 05:18 AM
AMS13
Aug 20, 2015 07:26 PM
goatbelly
Jul 12, 2015 10:13 AM
Naughtygoose
Jul 6, 2015 09:59 PM
