Rear Door Window Moves
Old Jun 1, 2004 | 02:57 AM
Spider13's Avatar
Default Rear Door Window Moves
I was washing may car today and went to wipe the window on the rear door and the window moved. It moves side to side at least 3/4 of an inch to a 1/2 inch. It also moves up and down some. I was wondering if anyone else had this problem. If so is a quick fix or should i take it to the dealer? I have to get my free oil change soon so i figured I would have them look at it then.
Ps This is the big window.
Old Jun 1, 2004 | 03:40 AM
softrider's Avatar
Take it back to the dealer. Don't think there any danger of it falling out, assuming the rubber molding is in place. But it shouldn't move around that much.
Old Jun 1, 2004 | 04:51 AM
k4kas's Avatar
DeepSouth Scions
Defenitly take it in!
I dont think it will fall out either.
But it may definatly may be causing a water leak.
Do you hear any wind noises when cruising down the road?
Old Jun 1, 2004 | 12:21 PM
Spider13's Avatar
No water(not in the cabin anyway) and No noise. Thats why i was so surprised when it moved.
Old Jun 1, 2004 | 08:05 PM
Spider13's Avatar
Well of corse when i get to the dealer to show them it won't budge. I guess maybe it was down just a tad or something. I'll just watch it and see if it falls out going to the interstate.
Old Jun 2, 2004 | 12:50 AM
softrider's Avatar
Humm, you mentioned in your first post that you noticed that it moved when you were washing your box. So wet your back window and see if it moves. Also if you attach a suction cup to the window, that would help you grab it. Perhaps it's just a matter of them reapplying the gasket adhesive.
Old Jun 3, 2004 | 08:25 PM
ScionXb's Avatar
This loose window you talk about, is it the roll down window or the smaller piece mounted in the door frame?
That smaller one seems to be loose on mine also.
IceBox
48
Mar 15, 2004 03:51 AM
yanges
30
Feb 11, 2004 03:49 AM
jonathan
Dec 1, 2003 11:28 PM
yanges
13
Nov 29, 2003 10:37 PM
iglooxb
Nov 6, 2003 05:42 AM
