EVERYONE WITH TEIN-H TECHS !!!!!!!!READ!
Old Jun 21, 2006 | 07:33 PM
jasonbegin's Avatar
Default EVERYONE WITH TEIN-H TECHS !!!!!!!!READ!
is anyone having problems with Back tires Wearing really quickly?
or any Wear on any tires? im seeing it in the back, ALOT and i have GOOD quality tires, maybe a camber kit was a good idea.
huh?
Old Jun 21, 2006 | 07:43 PM
kjmira's Avatar
Big Sky Scion
I hope there aren't any issues w/ them. I was planning on ordering mine next week.
Old Jun 21, 2006 | 08:29 PM
starglorystar's Avatar
How long have you had your springs on the car?
Old Jun 21, 2006 | 08:31 PM
jasonbegin's Avatar
about 2,000 miles or so
Old Jun 21, 2006 | 08:32 PM
Did you have an alignment done after installing the springs?
Old Jun 21, 2006 | 08:36 PM
Syxxpac's Avatar
Team No Limitz
Scionetics
its normal... with the camber from lowering springs, the inside of your back tires are going to wear faster than the rest. just get an alignment to lessen the wear on the back tires. and rotate them when you are supposed to and you should be fine. my car is dropped 2.25 inches and i never got an alignment or rotated my tires and i put 27000 miles on the tires before replacing them. so with the alignment and rotations the tires should last a little longer.
Old Jun 21, 2006 | 08:49 PM
2redgerm6's Avatar
its not normal to have noticeable wear in 2000 miles your toe is probably screwed cause that causes tire wear a lot more than - camber get an alignment.
EVERYONE SHOULD GET AN ALIGNMENT EVERY TIME YOU CHANGE RIDE HEIGHT OR ADJUST SUSPENSION!!!
Old Jun 21, 2006 | 08:53 PM
ack154's Avatar
Likely an alignment... and don't go thinking it's automatically the camber - the most common problem after lowering is to have a lot of TOE-in - especially on the rear.
Old Jun 21, 2006 | 09:05 PM
jasonbegin's Avatar
lots of shops keep telling me i need a camber kit, and a allignment will not do S h i t
im getting the allignment done This week...
so sick of the BS
Old Jun 21, 2006 | 09:49 PM
TCpete's Avatar
alignment bro.
shops = money takers!!!
Old Jun 21, 2006 | 11:32 PM
Syxxpac's Avatar
Team No Limitz
Scionetics
ok its normal if you dont get an alignment. well it should be expected anyway. haha. like i said i never got an alignment either but my tires lasted me 27000 miles. just got an alignment and brand new tires so i should be good to go.
Old Jun 22, 2006 | 02:40 AM
RAMROD7's Avatar
No tire rotation for me, should get me then about 15k.
Old Jun 22, 2006 | 02:44 AM
Garage1217's Avatar
Dood. your alignement is WAY off if you just installed springs and drive your car. You do NOT need a camber kit with the h-techs. it will align within spec. You lower your car and do not have an alignment, mad tire wear is expected no matter what.
DougC
Feb 22, 2015 02:39 PM
stayintrucha
Scion tC 2G ICE & Interior
Dec 18, 2014 04:36 PM
Itsdchz
Jun 30, 2009 04:54 AM
Slopoke21m
54
Apr 23, 2007 12:25 AM
BlueBox
14
Jan 15, 2004 01:08 PM
