What Tire pressure?
Old Jun 26, 2004 | 02:17 AM
3xv's Avatar
3xv
Default What Tire pressure?
What tire pressure are you guys running on your aftermarket tires/rim combo? Thanks
Old Jun 26, 2004 | 02:34 AM
Minsk99's Avatar
Look on the side of your tire. Most will tell you what psi to use.
Old Jun 28, 2004 | 05:28 PM
claffeyb's Avatar
On any motor vehicle, the tire pressure on the tire is not necessarily the pressure since that tire may be used in many different applications. That is the maximum recommended which should not be exceeded.
With the standard tires, the tire pressure to be used is that which is in the owners manual, and usually posted on a door pillar, glove box or inside gar cap door. When you go to aftermarket tires/rims, I believe that if they have the same speed rating and are same size, you stay with vehicle mfrs recommendation.
From discountire.com: Another valuable resource is the Tire Load/Inflation Tables. Your nearby tire dealer should have a copy. Not only will this document tell you the correct tire pressure for stock sizes, but it will provide the information on optional plus sizes as well. A good example would be the findings on a Honda Civic with the stock size 185/65R-14; recommended air pressure is 28 psi. Plus one size is 195/55R-15 with a recommended air pressure of 32 psi. Plus two size is 205/45R-16 with a recommended air pressure of 36 psi. Note how the air pressure increases with plus sizing to meet the load carrying capacity for the car.
Old Jun 29, 2004 | 02:24 AM
3xv's Avatar
3xv
claffeyb-Thank you for the information. I'm currently running 36psi. F 35 psi. R on 215/40/17 tires, so with the info. you just provided, I think I'm very close to the actual recommended pressure for my aftermarket tires. Thank you again. Have a nice week :D
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
kingofthecrate
Jan 21, 2015 09:28 PM
JDMxB
23
Feb 26, 2004 06:16 AM
Strader
Oct 12, 2003 11:46 PM
