Removing steering wheel who Knows how????
Old Jul 7, 2006 | 04:12 AM
scion06_tc's Avatar
Default Removing steering wheel who Knows how????
I was wondering if anybody knows how to remove the steering wheel, and if its really hard cause i want to change it.
Old Jul 7, 2006 | 04:32 AM
Neothin's Avatar
should take about 2 minutes to take off. there are two torx screws around the back of the steering wheel (not necessarily on the back, but on the sides in the back). loosen those up and htat will allow the airbag/horn assembly to fall forward. IIRC the main nut that holds the wheel onto the hub is now accessable.
Old Jul 7, 2006 | 08:29 PM
engifineer's Avatar
I highly reccomend disconnecting the battery for about 30 minutes before hand and even pulling the connector for the airbag harness loose to be good and safe about the airbag system. If they followed the standards I believe the connector will be yellow. Granted, it should not go off.. but it has happened before.
Old Jul 7, 2006 | 08:59 PM
SquallLHeart's Avatar
happened before? i don't remember hearing about it. yipe
but yeah... look for the yellow. when you open it up.. the wires are yellow too.
Old Jul 7, 2006 | 09:41 PM
engifineer's Avatar
^^ I havent heard of it on a tC, but I have heard of it happening on other cars with airbags.. The funny ones are thieves that were stealing peoples airbags and selling them.. those things cost some bucks.. some of them, however, were seriously injured because they took litlle care with them and they went off :D
Old Jul 8, 2006 | 02:34 AM
scion06_tc's Avatar
Thanks i want to put a sparco,momo,bride,etc kind of steering wheel just not sure which one i want.
Old Jul 8, 2006 | 03:42 PM
Neothin's Avatar
IIRC it's a t30 sized torx head bit
Old Jul 12, 2006 | 10:10 PM
scion06_tc's Avatar
Does anybody know where i could a bride steering wheel!!!
Old Jul 12, 2006 | 10:20 PM
WeDriveScions's Avatar
It's not that easy.... LoL
Yeah, the torx bits are there, but there is a whole cable assembly that has to pop off, plus the shaft bolt as well... it'll take more than 3 minutes... it's pretty straightforward, but you will lose your horn, turn signal cancel, cruise control, and air bag... it's all in a ribbon cable that you have to disconnect.
Old Jul 12, 2006 | 10:21 PM
insanetc's Avatar
wut about a quick release who has one and what do you do aftre you unscrew the steering whell from factory hub...
Old Jul 12, 2006 | 10:54 PM
I have one...
You need a hub adaptor and quick release setup...
you just connect the hub adaptor and then connect the quick release setup to the adaptor and you're good to go...
The hub adaptor just bolts on with the stock nut and then the quick release attaches to that and then your wheel...
Old Jul 12, 2006 | 11:11 PM
insanetc's Avatar
can you post a pic..which set-up do you have..and how is it..like getting out and driving u feel any diff...
Old Jul 12, 2006 | 11:19 PM
https://www.scionlife.com/forums/vie...ht=hub+adaptor
That's a thread of my quest to find the right parts...
it's nice, but losing some of the features is a bit of a bummer...
Old Jul 16, 2006 | 04:49 PM
scion06_tc's Avatar
Man i didnt know u lose the turnsignals i was hoping to leave this as a permanent mod!!!
CombatmedicR56
Nov 12, 2020 01:53 AM
fur_pig
Mar 20, 2020 04:28 PM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
Beesh
Jan 9, 2015 06:30 PM
